need to check my wiring for gm maf
Old Apr 14, 2006 | 10:22 AM
forum04pl's Avatar
first off let me say that i have read the manual so i really dont feel like being hassled about that.
here is how it went. i have a 3" gm maf and the lt1 splice harness. black pigtail on the harness i connected to the black wire on the stock maf connector (this is the only one i was unsure about doing all together), the pink on the harness i connected to the 12v source on the stock maf connector wich i believe is the 4th wire in from the left. the yellow i connected to pin 4 an orange wire in group A going to the ecu plus hu BUT i left the other half of pin 4 going to the stock ecu unconnected when i spliced into it. should i have had it connected both ways or just the way i have it?
now for the changes inside the car. i sent pin 15 a yellow wire in group B on the ecu plus hu to the stock ecu pin 85, BUT i only sent it to the stock ecu, i left pin 85 going to the stock wiring harness not connected. next i sent pin 16 a green wire in group B on the ecu plus hu and connected it with pin 33 a red wire in group D on the ecu plus hu BUT i left the other half of pin 33 going to the stock ecu not connected. i then sent these two wires that are now connected to the stock ecu at pin 72 and connected them, BUT it is only going to the stock ecu so the rest of pin 72 going to the stock wiring harness is not connected.
let me know if i need to change any setup with this
Old Apr 14, 2006 | 10:36 AM
SSKILLA's Avatar
HMM little confused on what the question is
Old Apr 14, 2006 | 10:37 AM
forum04pl's Avatar
is the wiring correct? do you seen antyhing wrong with the way i set it up?
Old Apr 14, 2006 | 10:38 AM
forum04pl's Avatar
also did you set it up any differently?
Old Apr 14, 2006 | 10:43 AM
SSKILLA's Avatar
first of all you should ground the gm maf to the chasis it will save you alot of trouble....dont connect it to the stock maf........
forum04pl's Avatar
alright ill do that now, anything else look out of place other than that
Old Apr 14, 2006 | 10:44 AM
SSKILLA's Avatar
check your pm...
Old Apr 14, 2006 | 10:50 AM
SSKILLA's Avatar
i pmed you my # just call me in a hr and ill help you with your setup......
Old Apr 14, 2006 | 12:41 PM
SSKILLA's Avatar
well hopefully that helped.....you should ask tom about your manual ....that was very weird
Old Apr 14, 2006 | 01:10 PM
forum04pl's Avatar
yeah im going to send him an email when he gets back to me about not being able to connect. figures now my battery is dead. ill let you know how if it made a difference in a few minutes. thanks again for the help.
Old Apr 14, 2006 | 01:11 PM
SSKILLA's Avatar
no prob
Alchem1st
Mar 15, 2022 08:47 AM
llDemonll
Sep 22, 2021 05:43 PM
fafaforza
Sep 29, 2020 10:53 AM
Evo_AK
16
Sep 28, 2015 12:26 PM
