Open ECU
Old Apr 27, 2006 | 08:11 PM
Juiced's Avatar
Can you make a list of the tunable parameters available on the first Relase of the software. so we can make it a sticky.
Old May 4, 2006 | 10:36 PM
DanJ's Avatar
it sounds like a descent plan, it isn't that great of an idea to just use someone elses map though, just because it works for you doesn't mean it'll work for somebody else.
Edit: woops, I misread your post, it does sound like a good idea
Old May 4, 2006 | 10:50 PM
PeteyTurbo's Avatar
I think he is talking about what CAN be adjusted rather then specific settings.
Old May 8, 2006 | 03:37 AM
colby's Avatar
I think you will find that what can be adjusted will increase very often once the software is released. The reason is that the software is general purpose, and if you are able, anyone can locate new maps / tables and add them to the ROM definitions. This in turn allows you to edit that new parameter. Put another way, what the software can edit is only limited by what people can find in the ROMs. Jason @ Mynes is finding new stuff every day, and I will keep adding that stuff to the new software releases.
Colby
Old May 8, 2006 | 04:06 AM
MalibuJack's Avatar
Not to mention I'm sure they will find code hacks too..
