low power for a tuned evo?
Okay so my bros car was just tuned and it has 272 int and exh cams. walbro 255, turboxs turboback with factory cat, bigger front mount, intake and boost controller set to 19 psi. His final power was at 270 ish at the wheels(dyno jet). We think it seems too low. Any input appreciated
Originally Posted by smoothmarine187
thats probably about right, your only at 19 psi and you don't have a high flow cat/test pipe, or a down pipe.....
That is a bit low. What year is your car. I have an 03, when I did my tune,I had a turboback exhaust, intake and ebc at 21 and stock everything else. I made 286 hp and 265 trq. on a mustang dyno. You having cams and should definately make more than me.
No offense but using a factory cat is the most ridiculous performance decision ever.
Get a high flow random technology cat at the least, or a resonated test pipe for optimum power and the resemblence of a cat.
At least change the factory cat to a high flow cat to help with the air flow. I had a magnaflow high flow cat on my car and put down 321 awhp. Than I switched to the straight pipe and put down 332...so the high flow cat isn't as restrictive as I expected. But factory cat
Also I am running 21 boost.
BTW - in cali they are really craking down on people who modify exhausts and it is no joke when they give you one of them smog tickets (I know they gave me one)
While I like high power as mush as the next guy, (and would not put a cat on my own car, it is not irrational to follow the law and mainatin the factory cat - not everyone is a law breaker
Originally Posted by DynoFlash
Ridiculous unless you care about legality and the environment
alexc
Feb 11, 2015 07:56 PM
Alfriedesq
Jan 22, 2004 09:51 AM
