Open Loop Fueling always on? Need some help
Old May 28, 2006 | 07:12 AM
Mad_SB's Avatar
Folks,
So, I have doing some logging in preperation for gettin an E-Flash from dynoflash to use as a baseline for EcuFlash tuning. I closed the txs auxilary boot bleed valve, set the map switch back to map 0 and went for a run.
I noticed right away my afr's were leaner than expected ending up at 11.1 at 7,000 in third gear. I checked the logs and noticed the maf signal was still being modified by the utec.
So, I turned off open loop fueling (set it to zero) saved, turned off the car, restarted, verified that olf was off and went for another run. Same result, the UTEC is still modifying the maf signal and seems to be running off the back ground map. This time I ended up at about 10.5 afr but the maf signal still seems to be getting modified.
Here is a log example:
2207, +0.5, 250,100, 10, 00, +17.2, 9.9,ECU. , +0.0,ECU. , 293, 13.95
2267, +1.4, 333,100, 10, 00, +16.1, 11.5,ECU. , +0.0,ECU. , 312, 14.00
2370, +2.1, 300,100, 10, 00, +16.2, 13.5,ECU. , +0.0,ECU. , 336, 14.22
2440, +2.9, 311,100, 10, 00, +16.3, 14.0,ECU. , +0.0,ECU. , 377, 14.22
2498, +3.6, 378,100, 10, 00, +15.2, 13.7,ECU. , +0.0,ECU. , 382, 14.08
2635, +4.3, 421,100, 10, 00, +14.9, 17.0,ECU. , +0.0,ECU. , 382, 14.00
2712, +5.0, 505,100, 10, 00, +13.2, 18.3,ECU. , +0.0,ECU. , 404, 14.00
2829, +6.0, 414,100, 10, 00, +12.9, 19.3,ECU. , +0.0,ECU. , 534, 13.78
2913, +6.9, 508,100, 10, 00, +10.7, 20.6,ECU. , +0.0,ECU. , 519, 13.68
3030, +8.1, 513,100, 10, 00, +7.9, 25.9,ECU. , +0.0,ECU. , 600, 13.47
3174, +9.5, 773,100, 10, 00, +7.3, 30.3,ECU. , +0.0,ECU. , 818, 13.06
3284,+11.2, 618,100, 10, 00, +6.4, 35.6,ECU. , +0.0,ECU. , 697, 12.75
3432,+13.4,1035,100, 10, 00, +6.4, 40.8,ECU. , +0.0,ECU. , 988, 12.64
3591,+15.5, 778,100, 20, 00, +6.8, 44.9,ECU. , +0.0,ECU. , 851, 12.59
3728,+17.4, 932,100, 30, 00, +6.8, 45.4,ECU. , +0.0,ECU. ,1024, 12.45
3889,+18.9,1219,100, 40, 00, +7.8, 48.6,ECU. , +0.0,ECU. ,1000, 12.37
4045,+19.6, 834,100, 40, 00, +7.9, 49.0,ECU. , +0.0,ECU. , 946, 12.37
4187,+20.1,1319,100, 40, 00, +8.0, 54.2,ECU. , +0.0,ECU. ,1344, 12.21
4368,+20.3,1057,100, 50, 00, +8.8, 53.7,ECU. , +0.0,ECU. ,1098, 12.02
4504,+20.5,1190,100, 50, 00, +8.7, 54.1,ECU. , +0.0,ECU. ,1219, 11.92
4681,+20.5,1285,100, 50, 00, +9.7, 60.2,ECU. , +0.0,ECU. ,1111, 11.93
4789,+20.3,1269,100, 50, 00, +9.8, 58.5,ECU. , +0.0,ECU. ,1295, 12.00
4982,+20.1,1253,100, 50, 00, +9.8, 62.3,ECU. , +0.0,ECU. ,1190, 11.98
5104,+19.8,1340,100, 60, 00, +9.8, 63.8,ECU. , +0.0,ECU. ,1436, 11.80
5257,+19.6,1420,100, 70, 00, +10.0, 68.5,ECU. , +0.0,ECU. ,1157, 11.65
5376,+19.3,1449,100, 70, 00, +11.2, 71.3,ECU. , +0.0,ECU. ,1388, 11.58
5509,+19.1,1377,100, 80, 00, +11.3, 71.8,ECU. , +0.0,ECU. ,1265, 11.45
5649,+18.9,1315,100, 70, 00, +12.1, 69.7,ECU. , +0.0,ECU. ,1250, 11.37
5777,+18.6,1449,100, 80, 00, +13.4, 75.3,ECU. , +0.0,ECU. ,1404, 11.27
5899,+18.4,1416,100, 80, 00, +13.3, 74.1,ECU. , +0.0,ECU. ,1358, 11.11
6006,+18.2,1479,100, 80, 00, +14.4, 77.8,ECU. , +0.0,ECU. ,1501, 10.96
6127,+17.7,1547,100, 80, 00, +15.5, 78.3,ECU. , +0.0,ECU. ,1479, 10.78
6242,+17.7,1461,100, 80, 00, +16.4, 82.0,ECU. , +0.0,ECU. ,1488, 10.65
6373,+18.2,1497,100, 90, 00, +18.4, 81.8,ECU. , +0.0,ECU. ,1562, 10.68
6497,+17.7,1577,100, 90, 00, +19.5, 77.4,ECU. , +0.0,ECU. ,1533, 10.71
6587,+17.4,1510,100, 90, 00, +20.6, 80.8,ECU. , +0.0,ECU. ,1445, 10.73
6693,+17.0,1515,100, 90, 00, +20.4, 82.0,ECU. , +0.0,ECU. ,1650, 10.68
6775,+16.5,1607,100, 90, 00, +19.4, 86.2,ECU. , +0.0,ECU. ,1538, 10.55
6872,+16.5,1677,100, 90, 00, +20.0, 88.8,ECU. , +0.0,ECU. ,1582, 10.45
6973,+17.0,1524,100, 90, 00, +20.1, 88.0,ECU. , +0.0,ECU. ,1582, 10.40
7062,+17.7,1543,100, 90, 00, +20.2, 92.1,ECU. , +0.0,ECU. ,1730, 10.36
Mod list is ultimate racing turbo back w/highflow cat, k&n Panel filter (yes I am going back to a stock filter cause the k&n seems to be causing the maf signal to bounce around). Utec firmware is version 1.7.
I have not changed any injector scaling, ecu is still the stock rom etc etc.
Any ideas????
Old May 28, 2006 | 07:24 AM
MalibuJack's Avatar
Well, first, I don't see anything wrong, Its saying ECU +0.0 and ECU which means its running off ECU for everything.. HOWEVER.. if seems like its not saving the settings, make sure the UTEC isn't in reflash mode and in run mode.. (Its in the documentation for the switch position)
Verify OLF is turned off, but did you rewrite your maps? Go into one of your fuel maps and set it to E for ECU and see if it goes back, if it does, its back in intercept mode and its disabled.. Setting the fuel map to 0 is different than setting it to E (ECU)
Old May 28, 2006 | 07:31 AM
Mad_SB's Avatar
Jack,
I agree that it says it is not modifying the fuel or timing, however take a look at the modified maf column.......
It did save the setting (open loop fueling to 0) but I have not cleared out my maps, they are still there but it does not seem to be using them. It does seem though that it is using the background map which I thought would be disabled with OLF off and the switch set to map 0.
I will take a look the the jumpers today, and may just reflash and delete all the maps, right now I just want to use the utec for logging so I can get to work on my ecuflash map.
Old May 28, 2006 | 07:33 AM
dryad001's Avatar
Just log on Map 0, whenever I can get my car running (hopefully next week) I'll post up some new logs.
Old May 28, 2006 | 09:12 AM
Mad_SB's Avatar
It is on map 0, that is where the above log came from.
That was the cause for alarm in the first place. It is on map 0 and open loop fueling is turned off, but the utec is still reporting a modifed maf signal.
Perhapse it is not modifying the signal, as indicated by the ECU in the fuel correction column, but simply reporting what it would modify the maf signal to if it were in open loop fueling mode in the modified maf column.
I'm not sure at this point. I Just thought the stock ecu would be running richer than it seems to running and the logged modified maf seemed like a likely cause.
I do not have any old logs before 1.7 with the afrs, since i did not get my tuner pro until after I upgraded to 1.7.
Any more ideas guys? I think I am going to delete all maps and create a fresh closed loop map with timing and boost set to ECU and fuel set to 0 and see how that logs. Thanks for help so far though guys.
Old May 29, 2006 | 06:10 AM
MalibuJack's Avatar
I went and checked on my UTEC before I removed it.. +0.0 is the value if its unmodified regardless of whether OLF is enabled or disabled.. I do recall it saying ECU at some point so it was probably the original output before v1.7 of the firmware came out.. If your really uncomfortable, then just reflash it with 1.7 again and it will reset everything back to factory inthe process.
Old May 30, 2006 | 01:11 PM
Mad_SB's Avatar
O.K.
I just called TXS and talked to Nathan about this. What he said is that each sample is taken in series. So, the logs are not an actual snapshot of all the parameters at a given instant, each field is sampled independantly so they are skewed by a few milliseconds. In other words the first MAF colum data is the maf data at the instant of the sample and the mod maf column is a snapshot of the maf value a few milliseconds latter.
So the long and short of it is I was doing things correctly but did not understand the sample rate and how that would affect the logs.
Old Jun 2, 2006 | 07:50 AM
EVO8LTW's Avatar
Am I reading that log correctly that the stock ECU has the AFR in the 12s with 19-20 psi of boost in the 3800-4400 rpm range? I thought the stock ECU ran much richer than that. That seems a little aggressive for even a modified tune, but maybe I'm just too conservative.
Old Jun 2, 2006 | 08:03 AM
MalibuJack's Avatar
you do see 12:1 AFR's in passthrough mode if your running higher than stock boost, an aftermarket intake and exhaust.. This is why tuning is your friend.
I forgot to mention earlier that each sample is a MS or so behind, so what your seeing are MAF values that are sampled at slightly different moments..
Old Jun 2, 2006 | 11:29 AM
Mad_SB's Avatar
Yeah that is part of the reason I thought something was wrong. 12's in the midrange with bcs restrictor pill removed at 20 psi and 10.5 in the 7000 range at only 16.5-17 psi. I thought it was too lean to be the real stock values as well.
My car has always been screwy with the base map though, I had to add a ton of fuel to the utec open loop fueling base map to get my afr's in the 11.5 range up top at around 19psi. I may have a screwy maf, notice how much the reading is bouncing around???
At the time of that log, the only intake I had was a k&n drop in filter. I pulled it out the same day and replaced it with a stock mitsu filter, maf is still screwy though.
