maf
Old Jan 22, 2010 | 09:02 AM
X91EVO's Avatar
Registered User
^^ they been saying that for years
Old Jan 28, 2010 | 06:13 PM
DEV0LUTI0N's Avatar
Utec with speed density
Originally Posted by JamesAlipo11
Can you run a utec with a speed density setup????
Yup
Dtec Sensor MAP (Dtec-MAP) US$99.00 The DTEC-MAP is a plug-in manifold absolute pressure sensor that allows the DTEC to measure and datalog boost pressures up to 45psi. DTEC-MAP also plugs directly into the 350Z-UTEC giving you the ability to tune forced induction 350Z's using Speed-Density tuning mode. TurboXS highly recommends purchasing this for forced induction 350Zs.
DTEC MAP sensor Adaptor for EVO8 UTEC (Dtec-MAP-AD) US$5.00 This adaptor allows you to plug in our DTEC-MAP sensor into your EVO8-UTEC
