avcr setting help
Subscribe
Jul 18, 2006 | 10:41 PM
I did a search and found nothing to my needs.
I need help setting the settings on the avcr. I understand the boost and duty to set the boost but what about the learn gear.
DOES ANY ONE HAVE AN AVCR DIALED IN FOR 25 TO 28 PSI THAT COULD GIVE ME THERE SETTINGS THROUGH OUT THE AVCR.
last time at the track i would sometimes hit 20 psi and sometimes 30 psi both on 104 race gas, i would rather it be safe and consistent also while utilizing the rest of my avcr settings.
Reply 0
Jul 19, 2006 | 10:11 AM
bump
Reply 0
Jul 19, 2006 | 10:18 AM
Dude just call Apex-i they are very cool and always willing to help. hit them up . . . 714-685-5700
Reply 0
Jul 19, 2006 | 10:25 AM
Are you setting it up for each gear or in general. The purple signal wire on mine is hooked up to the TPS not the rpm sensor so I cannot adjust my boost specifically in each gear. What I do is set a target boost pressure and just keep adjusting the duty 5% at a time. Then when I get it to where I want it, then fine tune the duty 1% at a time. That has been rock solid for me so far. I only run about 23psi though so I dont know if it makes a difference.
Reply 0
Subscribe
