what gain does SAFC tune make vs. stock?
Old Oct 5, 2006 | 09:33 PM
TTP Engineering's Avatar
Originally Posted by turbolarry
Way to make a sale. You really should do that for everyone outside of central Florida because that is what's better for the car. Something over the counter like leaning out the high map a little and topping out the timing to 18* isn't going to be as good as something custom. Of course I'm sure you do much more, look at the possabilities from flashing;
http://www.openecu.org/index.php?title=Main_Page
Both you and I know there are limitations from an AFC, just like there's limitations on $199.00 three time zones away.
Any of those threads from CA and on 91 octane?
I do it for everyone outside of central FL. From Hawaii to Wisconsin, NJ and in other countries. Just did a remote custom for a 95RON car in the island of Dominica in the carribean. 95RON is the USA equivelent of 91oct (R+M/2).
We will be remote custom tuning the Evolutionm.net project evo in the next few days LIVE via dynocam using our RemotEflash(tm) product to demonstrate its effectiveness.
Old Oct 5, 2006 | 09:39 PM
Ph3n1x's Avatar
I dont think theres a single person who isn't satisfied with their Tune from TTP. Well there are people......Just the people who haven't done one yet
Old Oct 5, 2006 | 09:44 PM
Evo_Jay's Avatar
1. Everyone knows that an AFC doesn't control timing that's not the argumnet. Is it crude, ghetto, and all that? Yes. Does it work and make power? Yes.
It makes horsepower and that does get you down the 1/4 mile faster, but I like to have torque down low and you need control of timing to get that.
Also, you know theres three parameters in tuning; fuel, timing and boost. Why would you only want to be able to adjust two of them??
Old Oct 5, 2006 | 09:48 PM
BBYBruno's Avatar
+1
Old Jan 19, 2007 | 11:32 PM
MR_EVO21's Avatar
Question I know it probably was answered somewhere is this forum but if you change anything in your setup do you have to get another reflash?
Old Feb 10, 2007 | 10:21 AM
Eastwood95's Avatar
The AFC doesnt control timing directly, adjusting the A/F ratios's correctly will manipulate the timing to where it's supposed to be though.
Old Feb 11, 2007 | 10:38 PM
aenzo24's Avatar
you can still use a flash + a safc for fine tuning, last time i looked a 4g63 is a dsm and people have benefited from a safc for years. a safc is a good choice for basic tunning but you must have general concept of tunning to use one.....any data logging software such as evoscan could also help you with the use of a safc.
Old Feb 18, 2007 | 08:40 AM
EVOllie's Avatar
Ive been messing with cars for yearssss. and before stand alones came about, that was always the way to go on a turbo cars. Flashed ecu and an AFC.
On my evo i had a mail in flash, so its kinda hard to get it were u want it. My A/F were around 10.8s. I then fine tuned it with my AFC and gain alot of WHP. By taking fuel out and bringing the A/F to mid high 11's.
Plus flashed ECU's dont compensate for change in wheather, That where my AFC comes in handy.
Old Feb 18, 2007 | 11:26 AM
aenzo24's Avatar
safc
i totally agree, everyone is all about the flash but it a set thing not easily adjusted. the safc + flash is the way to go.
Old Feb 18, 2007 | 03:27 PM
Evo_Jay's Avatar
This is WRONG. Dont spead lies.
The only reason I can see running a AFC, would be with a flash, for fine tuning or race gas.
But then again you can get "the cable" and ECUFlash for $80, alot cheaper then a AFC and harness, and be able to fine tune a flash or load a race gas map.
Old Feb 18, 2007 | 03:28 PM
Evo_Jay's Avatar
Flashes CAN be easily adjusted. Stop spreading lies please.
Old Feb 18, 2007 | 09:19 PM
aenzo24's Avatar
this guy is not taking into consideration that not everone owns a laptop......obd cable + laptop = alot more money than safc. anyway i find it more convenient to switch between my preset fuel maps for track and road use on my safc, also its easy to make minor changes to a/f ratios due to temperature changes.
Old Feb 18, 2007 | 10:25 PM
cpoevo's Avatar
The way the AFC works is it tricks the ECU into thinking it is running at a lower load. If you look at the timing tables that are used in our cars you will notice that the timing increases at a certain RPM as the load is lower. By adding larger injectors you can pull even more fuel and move the "load cell" even lower adding even more timing. There is a oint at which your timing advance will be too much. I was running 780 and had an AFR of 10.4 with 24* at 7400 RPM in my opinion that is just way too much timing for pump gas at that RPM, especially 91oct. I have since started using Ecuflash. Is it harder to learn and tune than the AFC? YES. The nice thing about the AFC is you can tune it yourself and make adjustments on the fly. You can also make 2 maps one for race gas and one for pump gas.
Old Feb 22, 2007 | 04:23 AM
Eastwood95's Avatar
Ok, so everyone agrees...........yay.
Get a flash, and fine tune it with a SAFC + Wideband/Datalogger
Enough arguing already......
Old Mar 1, 2007 | 05:06 PM
ctninea's Avatar
I pulled 303 awhp with a MBC, catback and tuned safc-2. I beleive that Safc's can take u a long way. No need for a flash unless u gots money to burn
