power fc info needed
power fc info needed + 2 step??
ok, i might have found a good deal on a power fc, i was leaning toward the AEM but i may give this a shot.
so anyway, he is including the power fc, controller, and map sensor.
what else would i need to make it work?
is the D-jetro the one that utilizes the map sensor?
i want to make sure i am looking at the right thing and not be dissapointed down the road when it doesn't do what i want need.
also, is there any 2 step or how would you go about getting a 2 step set up for launching?
thanks
jon
thanks
jon
if its the powerfc, hand controller and map sensor then its likely to be the djetro version.
but, the boost control add on kit for the powerfc has a map sensor and a solenoid, so it might be best to clarify where its coming with the boost control kit or if its the djetro version.
theres is no 2 step launching with the powerfc, youll need a seperate external device. i think the gizmo launch control box can do it quiet nicely for you
what harness? it comes with the map and then plugs right into the factory harness??? trying to find out more info as to whether i should get this or wait and get the AEM
evotino
15
Jul 22, 2005 05:02 AM
