How many actually blew up WHILE RUNNING METH INJ?
Old Sep 10, 2006 | 04:40 AM
smokedmustang's Avatar
I haven't, but you hear about the "failsafe" kits, and if you don't have one, you go BOOM if there is an empty tank/problem with the system. How many have been spraying Meth/H2O etc... and while on the gas went KABOOM? If so, what caused it? bad wiring? empty tank? just curious.
Another question, if you are racing on the track (road course) does it matter how long of a "continuous" pumping of the meth you do? ie: Would a consistent spray on a race weekend (HPDE) type thin the oil out too much requiring frequent oil changes?
I also take it, once the red-light is on, (Empty tank) you have NO time to get out of the gas, you,in a sence,just go boom? Or is there some time of "danger-zone" where you can shut it down before catastrophic dammage. Thanks in advance.
Old Sep 10, 2006 | 06:23 AM
I guess not many are awake yet!
Old Sep 10, 2006 | 06:32 AM
cfdfireman1's Avatar
AFR's
And what where your target AFR's with the meth?
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
i just woke up....i blew up at initial throttle tip in (well cracked stock piston last year and rebuilt it overnight) cause the smc box went bad and didn't ramp methonal.... it just stopped spraying it till full (or wherever i had the full psi set at).
Dave
Old Sep 10, 2006 | 06:37 AM
Dave
Thanks Dave, OUCH! There are 2 "boxes" with mine, damn it is a tough call on when one will go bad. There is an IDIOT light that indicates its spraying, but how the hell do you know if it is ramping properly?? You get to a point when you are unsure if race-gas is a better bet. I have had my Meth kit for 18 months now, and FINALLY got it hooked up and working. just would hate to toast the AMS 2.3 for the "xtra" hp, when the gains are same-ish and safer with race-gas.
Old Sep 10, 2006 | 06:38 AM
I thought they should read about the same as with regular or race-gas, NO? great question. When I stomp on the accelerator, meth-spray light is on, and the A/F is 11.2-11.5. is that acceptable?
Old Sep 10, 2006 | 06:45 AM
onpol's Avatar
I think you are running conservative with those AFR and you shouldn't have any problems.
Old Sep 10, 2006 | 06:47 AM
Thanks onpol, just incase, would you send me your credit card number and expiration date? jk, thanks.
Old Sep 10, 2006 | 07:42 AM
jrsimon27's Avatar
look at a sticky shiv has he peaks boost at 13.0 and by redline he was at 12.0 so i think you are safe.
Old Sep 10, 2006 | 07:43 AM
Thanks again as ALWAYS jrsimon.
Old Sep 12, 2006 | 04:47 AM
aim for 11.2-11.3
Old Sep 12, 2006 | 06:18 AM
aim for 11.2-11.3
Thanks bro! Will do!
Old Sep 14, 2006 | 11:06 AM
Mase's Avatar
That wouldnt be a good rule of thumb, when u have the most load on the motor, you still want a nice rich(er) condition. 13.0:1 is too lean in moderate to heavy load. 12.5:1 is still pushing it, For conservation you want 11.8-12.0:1.
Old Sep 14, 2006 | 11:18 AM
DRFTKNGG's Avatar
I was told the the meth makes the wideband read lean.... The instructions say to start to tune at 12.0 a/f because the meth fools the O2 sensor, and doesnt read correctly.
Old Sep 14, 2006 | 11:19 AM
DRFTKNGG's Avatar
Plus the meth will take care of most of the knocking or pre-ign.
