At what point is "Lean", TOO LEAN? With meth. also.
Old Sep 10, 2006 | 06:41 AM
smokedmustang's Avatar
I step on the gas with the methanol spraying, and I see 11.2-11.5 at WOT. is that too lean? cause for concern? And when do you cross the line between "a tad lean" to GOD YOU BETTER GET OUT OF THE THROTTLE?
Just thought I would ask without searching first.
Old Sep 10, 2006 | 07:12 AM
Gary C's Avatar
Post
You could always buy another motor, seems a little on the low side.
Old Sep 10, 2006 | 07:14 AM
I want to have fun in the car now, not replace stuff anymore! Besides, I have to keep ahead of you BEFORE you go hog wild on your AMS 1,000 HP build!
A little low, meaning OK? too rich?
Old Sep 10, 2006 | 07:25 AM
Gary C's Avatar
Not a 1000,,,,,, torquey deal...
a/f is a/f,,, there is a magic number, 11's is the danger Will Robinson mode...
Old Sep 10, 2006 | 07:29 AM
So I should be in the 10's?
Old Sep 10, 2006 | 07:33 AM
Ang Wen Yan's Avatar
This should be ok.No knock is ok.
Old Sep 10, 2006 | 07:34 AM
jrsimon27's Avatar
a freind of mine bought the ams kit for water alchol injection it states in the tuning tips that one can have afrs between 11.0-11.4 and run 3-6psi more of boost! but before doing anything else my friend just use something to log timing i use pocketlogger!
good luck my friend!
Old Sep 10, 2006 | 07:38 AM
Thanks guys! I will keep you posted.
Old Sep 10, 2006 | 08:28 AM
broeli's Avatar
11.2-11.5 is definitely not too lean. Are you seeing that a/f ratio throughout the powerband?
Old Sep 10, 2006 | 08:32 AM
Mostly yes, it is more at WOT-ish, I see it get down in that range. it is in that range, sustained throttle, higher rpm's.
Old Sep 10, 2006 | 08:38 AM
DRFTKNGG's Avatar
11.2-11.5 is on the richer side.
My air/fuels are 12-12.2's. Remember, the meths tricks the wideband. So 12.0-12.2 are actually more like 11.2-11.7's.
Methonal suppresses knock! I use 50/50 for maximum protection from det. and knock. If
you read and do some homework....the h2o is just as important as the meth. Also less chance of washing the cylinders down, which decreases the lubrication properties of the oil.
The pro cars running meth, like the AEM car, and the Turbonetics solora that runs 7's.... all use 75% meth, 25% h2o.
Old Sep 10, 2006 | 08:40 AM
Great info!! Thanks alot. distilled water? what type. certanly not tap water, correct? Again, thanks for the great post.
Old Sep 10, 2006 | 09:58 AM
SlowCar's Avatar
distilled water from the grocery store. or if you know someone working in a lab with a deionizing system, 18Mohm water
Old Sep 10, 2006 | 10:30 AM
Don't know anyone in the deionizing department. but thanks for the tip!!
Old Sep 14, 2006 | 11:18 AM
elhalisf's Avatar
what about using windshield washer fluid?
