Only 9 Psi
Old Oct 8, 2006 | 01:08 AM
ReNoEvO775's Avatar
Only 9 Psi
ok i am very new to this so here is my problem i have a 2003 evo that is only boosting 9 Psi . I was told that there are special stock vaccum lines that cant be replaced this will mess the boost up. Is this true? also i think the person before me had some type of flashing going on can this effect it also . i bypassed the waste gate and still only 9 Psi. Please help
oh by the way i checked all the vac lines already and still have no clie what this could be
Old Oct 8, 2006 | 01:09 AM
ReNoEvO775's Avatar
the stock lines have been replaced due to the fact the old owner had a boost control
Old Oct 8, 2006 | 01:32 AM
2003raptor's Avatar
u did a boost leak test?
Old Oct 8, 2006 | 03:08 AM
06evofiji's Avatar
Go buy a MBC and turn it up see what happens...what you have heard is true you need you stock lines if you are running stock parts.
Old Oct 8, 2006 | 10:29 AM
ReNoEvO775's Avatar
ok so if what your saying is true the flashing of the compter could that have anything to do with it
Old Oct 8, 2006 | 02:56 PM
RevMoto's Avatar
If your stock boost controller(found below your intake) still has all the nipples on it then just connect your vaccum line to that.
Old Oct 8, 2006 | 09:00 PM
ReNoEvO775's Avatar
ok so i put a mbc on it and i am now getting 10 or 11 Psi but it runs better i think previous owner messed up the ecu he flashed it and did his own programing instead of someone who knew what they were doing
Old Oct 8, 2006 | 09:21 PM
Evo_Jay's Avatar
If you put a MBC on it and it wont go over 12-14, then theres something wrong with the lines and/or MBC. The ECU being flashed in anyway wouldn't do anything when using a MBC.
Go buy the lines from Mitsu (you need to get tehm here not at auto store) and get the car workin correctly before puttin on a MBC or any other mods.
Old Oct 9, 2006 | 08:31 PM
ReNoEvO775's Avatar
well he messed up the air fuel so as i understand the car won't boost if there is no gas for it to boost so i am taking it to the dealer to flash it to factory specs. what is the stock boost on these cars i was told 16 then i was told 19
Old Oct 9, 2006 | 08:43 PM
projekt_shocker's Avatar
i am pretty sure stock boost on evos are 19 psi.
Old Oct 9, 2006 | 08:51 PM
ReNoEvO775's Avatar
was or is yours on your 03 evo
mattchan99
23
Jan 10, 2014 04:28 PM
robyn402
Sep 12, 2010 11:43 PM
ArchieBabes
May 21, 2008 03:01 PM
razorlab
Feb 28, 2008 11:41 AM
Evo1X
Jan 28, 2007 11:18 AM
