Reasons for pulled timing after 5k RPM's?
Old Oct 10, 2006 | 11:46 PM
Turd Squirter's Avatar
What different factors would cause the factory ECU (EcuTek flashed) to pull timing after 5K RPM's? My tuner and I are pulling our hair out here. The car is an '05 VIII with a brand new IX turbo, 264in/272ex cams, Walbro 255lpm, 720cc injectors, MBC @ 22lbs of boost, and a TBE w/test pipe. The car has passed a compression check and leak down test with flying colors. The spark plugs are brand new. What are we missing?
Old Oct 12, 2006 | 07:27 PM
dubbleugly01's Avatar
any way of monitoring fuel pressure? Could be a weak pump or a poor connection in the fuel tank not allowing the pump to supply regulated fuel pressure to the injectors, but something less.
Old Oct 12, 2006 | 09:31 PM
Would poor fuel pressure be reflected in the AFR?
Old Oct 12, 2006 | 09:39 PM
BBYBruno's Avatar
Your timing is probably to agressive and you might be knocking after 5k so the stock ecu is pulling timing.
Old Nov 17, 2006 | 12:34 PM
Jeff_Jeske's Avatar
Put a splash of race gas in the tank and see if the problem goes away. If so then you are too aggressive on timing.
