question on which boost lines to use
hey guys, i do not know if this is in the right section or not so if it is in the wrong place mods please move it. ok, so i searched for my question and did not get the exact answer i wanted so i am posting to see if someone could help me. I bought a greddy profec bspec 2 and it comes with its own boost lines but i was wondering if using the stock ones would be better because of the restricter pill in it. I think it was warrtalon who said that stock lines with restricter pills are better because they hold boost better then stock lines without restricter pill but i read it awhile back so i could be wrong(please do not quote me on it). so my question is when i install my new boost control soleniod would it be better to use the stock lines or the lines they provide in the kit? And would the stock lines even fit in the new boost control soleniod?
Thanks in advance
Mike
Thanks in advance
Mike
I know nothing about the greddy profec bspec 2, however every post I've seen on changing to any boost controller has said not to use the stock lines.
I have just the Buschur MBC, and reusing the stock line was not even a consideration. I do know I hold boost without any problem at all, and get very accurate readings. I've been tuned on a couple different dynos and the boost I read is very very very close to what they are reading.
Hope it helps
Hope it helps
