OLF Question
Old Oct 18, 2006 | 06:51 PM
dubbleugly01's Avatar
OLF Question
If I turn OLF on, is it just for a particular set of maps, or is it on/off for all the maps? I've got the remote map switcher, and just wondering if I can turn it on for a particular set of maps (timing and fuel, say in map selector switch position #3) so that I can play around with it, and keep a good tune untouched in another location that OLF won't effect? I'd like to play with injector scaling, but only have it impact that particular set of maps in position #3.
Thanks in advance.
Old Oct 19, 2006 | 04:16 AM
DCsleeper's Avatar
OLF is a global parameter and therefore is either on or off for all maps. I would not tailor 1 map using OLF and another using CLF. You can imagine the issues you would have if one day you get them mixed up.
