Datalog Lab shows 294whp from a flash.
Bought a flash, ran a 4th gear pull, logged it in evosan 0.97. All I changed was the weight of the supplied evo8 template to that of the evo9 MR. Datalog lab shows 294whp. This can't be correct. All I can think is that the 'known power at known speed' must be different for the EVO IX. Or maybe I needed to SAE correct it?
Any ideas would rock- Thanks.
Car is bone stock apart from a vendor flash, so there is no way I expect there to be 294 whp from a flash. There are a few knock values. Still being a newb, I'm not really sure if what data log lab shows is all that good (or bad).
5 counts of knock is a bit much, you should remove a couple degrees timing from that load cell, maybe.
In regards to your DynoGraph from DLL - Default gear ratios are from VIII's, might wanna change those to the IX MR's gear ratios. This could affect the HP/TQ output in DLL.
Did you save a stock dynograph in DLL? Compare the two to see where you gained power
well i just did some dynoing on a stock evo 9 MR. it was totally stock and read 251hp on a mustang dyno (which is about 280hp on a dyno jet). after the flash, the numbers jumped to 267hp, about 300hp to the wheels. the data log software shows dyno jet numbers
the dyno from DLL tends to read higher compared to a mustang dyno. i read it somewhere on norcalevo.net that you have to make some adjustments on DLL to have the DLL dyno readings to match the mustang dyno readings.
