reflash or stock
reflash or stock
is there anyway to tell if my stock ecu has been flashed? if so how can i tell if it has been? i bought the car use and i can tell that it has been modified. the ecu has the previous owners name and "ok" wrote in pen on it.
thanks for your help
Most of the flashes that i have seen will raise your rev limiter to like 7800 or so. take it up and see if it will go there. ALso see if it has a lauch control that is a popular add on for the 03-04 evos also
download the map through ECU flash. is the primary and secondary (hi low octane maps) the same?If yes, then its been flashed (but not AL tuners do this) or compare your high octane map to another Evo that hasnt been flashed of same year and model. Having saved all of my maps from a couple of tuners thats what Id do.
