map remote switcher
Old Dec 4, 2006 | 03:53 AM
J!n K@z@mA's Avatar
map remote switcher
i bought my UTEC used so it didn't came with any instruction manual. i got the Utec installed but something i can't find out, where the heck do i do to the black wire that's with the switcher? this is the only reason why my switcher don't work. i called turbo xs for instructions but they told me it's in their site but i cant find the inst. for the switcher. help pls. pix would be appreciated too. it's the two blue thingys that looks like it plugs to some thing. it doesn't look like a ground wire
Old Dec 4, 2006 | 04:07 AM
EvoTech's Avatar
It is clear as day in the instruction manaul whch you can download off of their site. How did you know which pins to put the other 2 wires to? sorry but I am not diggig out my manual becasue you can't find it in your instructions.
Old Dec 5, 2006 | 06:30 AM
mikesevo8's Avatar
Don't be so harsh Ed
Did you download the manual from the TurboXS website yet ??
You will find the latest copy on this page - http://www.turboxs.com/evoutecupdate.htm
After getting the manual. look at info starting on page 53. That will give you the pinout of the molex conn.
Didn't your switch come with the 12pin molex connector on the end? It should just plug into the UTEC and work. Mine did.
If for some reason you are missing the connector, here is how mine is wired:
There are 5 wires in the main cable: red, white, light blue, light green, black.
black - pin4
white - pin5
lt green - pin6
red - pin11
lt blue - pin12
See the manual for the pin locations
I have these other 2 wires that come down from the switch in a separate gray cable, and I
don't know what they do yet, but I didn't need to hook them to anything to get the switch to work.
Old Dec 5, 2006 | 10:18 AM
EvoTech's Avatar
black - pin4
white - pin5
lt green - pin6
red - pin11
lt blue - pin12
I don't think that I was being harsh. He called turbo xs they told him to download the instructions which clearly state the wiring for the switch. It is like asking people what an intake will do for your evo. Do a search and you will find it all. The same is the case here. If he read the instructions it is all there. BTW The other 2 wires are for a clutch switch that is used on the WRX's not the Evos. No need to use them at all. If I came acrosss harsh, I am sorry but all the info you need is in the instruction manual that as you said is readily avialable on the Turbo XS site.
Old Dec 5, 2006 | 10:25 AM
mikesevo8's Avatar
I agree with you; I was just busting your *****...
Thanks for the update on the wires. Now I can just tape them off.
Hey, let's keep this thread going; it will put some activity back into this dead forum
Old Dec 5, 2006 | 01:00 PM
J!n K@z@mA's Avatar
don't know what they do yet, but I didn't need to hook them to anything to get the switch to work.)
these are the wires that i'm talking about, thanx. i'm not talking about the one for the accessory harness, i but i'll go check again on that. i thought these are the wires that is causing mines not to work
black - pin4
white - pin5
lt green - pin6
red - pin11
lt blue - pin12
Old Dec 5, 2006 | 01:03 PM
J!n K@z@mA's Avatar
you're not harsh at all, i guess it's just miscommunication. the wires that you just said that goes for wrx is the one i'm talking about.
Old Dec 5, 2006 | 05:44 PM
mikesevo8's Avatar
Truth be told, there is nothing in the manual about the switch harness, just the pinout of the connector.
I didn't know what those "extra" wires did either. But my switch worked fine when I plugged it in.
I checked mine out by changing the switch and watching the number change on the dashboard screen on my laptop.
It sounds like you are still having trouble getting your switch to work. Is this so??
