Problem holding up the boost in my EvoIX
Old Feb 12, 2007 | 04:47 PM
RUELASEVOIX's Avatar
Hi i just want to ask if its normal that my Greddy profec E-01 isnt mantaining boost levels up to redline. it gets a peak and then begans to drop up to redline. I'm runing at 27 psi with race gas, but in the dyno sheet i saw a peek of 28 psi between 4800 to 5500 and then begans to drop the boost to almost 20 psi when it gets near redline. I made a boost leak test and everything its ok, also i think maybe its the actautor of the wastegate, i dont know if the stock waste gate can hold up this boost. Im runing stock turbo.
Thanks
Luis
PD
These are the sets in the boost controller
Set 75 %
gain 5
start 20 psi
Old Feb 21, 2007 | 03:43 PM
FastAzzEvo's Avatar
i think an actuator will help, but there is numerous reasons why it isn't holding that much boost..
1 being that 27psi on a 16g is all hot air.
Old Feb 21, 2007 | 03:56 PM
evoboy83's Avatar
get a new actuator will help , your stock one ain't gona hold that much booost...
Old Feb 21, 2007 | 03:58 PM
Tribal's Avatar
All I Can Say Is Becareful And Take Your Ride To Pro.
