Zeitronix boost log - long decay time
Aaa, Nice job finding that. Now you should have faster boost response overall.
I should double check to make sure mine does not have a restictor in it, although I recently got a JDM map sensor and I don't really use the zt2 boost sensor anymore aside from being one of the ZAVT failsafe triggers.
my meth is triggered by a hobbs switch@10psig and the kalivco map sensor is also plumbed into the same boost line - all inside the cabin.
previosly, when i let off...the pressure/boost in the tubing is "slowly" vented due to the brass pill and meth is still spraying, i was shooting massive flames - no flames now
haha its a good thing the dyno guy was searching for a vacuum line source
that is such a great find, i'll post pictures of the actual restrictor tonight, i still have it in my wallet.
it should be noted though that any MAP source for meth injection should be located as close a possible to the manifold. i have enough logs to duplicate the same results Slowcar has here.
so its nothing to do with how zeitronix samples the data (we were confused because its 75hz or so, so plenty fast, yet the decay time is enormous). its how long the vacuum line is to the MAP sensor. my apologies to zeitronix for any blame on my part to their product, when they were correct in assume it was our setup. it should also be noted that the stock boost gauge vacuum line is over 10 feet long, with the restrictor in it. it is routed through the front fendor then into the cabin from inside the fender liner. its a very long path to take, and a terrible source to use for manifold pressure.
We would not design a lagy input to be coupled with the best pressure sensor on the market. Moreover, we test every input of every Zt-2 shipped out, plus every Zt-2 input is protected so it was very unlikely there was a problem with this Zt-2 unit itself. Glad you found the restriction in the vacuum line.
Happy tuning!
Please visit us at SEMA 2007 booth #20265
Zeitronix Eng
Blak94GSX
Evo X How Tos / Installations
21
Feb 4, 2015 03:02 PM
TTP Engineering
Evo 'For Sale' Interior Styling
141
Jun 3, 2010 10:21 AM
TTP Engineering
62
Apr 24, 2009 03:26 PM
500whp.com
40
May 18, 2006 10:29 AM
