High Knock
Old Apr 13, 2007 | 12:24 PM
Duby's Avatar
High Knock
Just the other day my friend got ecu-scan and we logged a few pulls on my car; The warning for knock was going nuts as I was getting over 10 counts of knock and 16 by 7k rpms. At Idle it's still 0 so I didn't think it was interferance. anyone have any idea or possible suggestions to a. help fix this or b. what interferance might this be after moving? I turned boost down to 18psi and still get about an 6-9 knock count by 7k. The car was flashed by Turbo Trix for 21psi on 93 octance. I'm going to log again this weekend with gas from a different station as I think maybe I just got a bad batch or somthing . . . a week prior I ran 12.5 @ 107 and felt I was losing top end somewhere . . . 4 gear just blu
Old Apr 13, 2007 | 12:27 PM
BOOSTEZ's Avatar
4th gear is one of the strongest gears in the car, so yea, you was probably knocking then. Why not just get a custom tune on the dyno?
-M
Old Apr 13, 2007 | 12:36 PM
Duby's Avatar
-M
we logged in 3rd gear, 4th gear at the track blu. I am going back for a custom tune though, cams should be here tonight when I get home from work
Old Apr 13, 2007 | 12:45 PM
spdracerut's Avatar
Probably just too much timing. It's easy enough to change it in Ecuflash. When the car starts feeling like *** and doesn't want to accelerate anymore, often times it's because a lot of timiing is getting pulled due to knock.
Old Apr 14, 2007 | 11:33 AM
Duby's Avatar
bump for any other oppinions . . . or ideas
Old Apr 14, 2007 | 12:50 PM
spdracerut's Avatar
Well, there's not too much to it. You generally get knock from one of three things: too much boost, too much timing, too lean. You can adjust those in any combination to reduce the knock.
Old Apr 15, 2007 | 11:46 PM
80210's Avatar
As said above.
1. Make sure your running safe boost levels
2. Richen it up a bit if needed
3. Then adjust timing as best you can without high counts of Knock
Seancj
Jul 2, 2015 06:22 AM
villero1834
Cobb AccessPORT
May 16, 2013 09:48 AM
Thomasevo
Oct 1, 2009 02:51 PM
tkklemann
Apr 28, 2007 05:52 AM
krillin
Feb 6, 2007 10:01 AM
