Ecu tune & Fuel Pump. Help a Nub out Please !
Old Apr 17, 2007 | 07:12 PM
theflyho's Avatar
Im getting a tune this weekend at GST motorsports and so far i have a downpipe, catback, and greddy intercooler with nisei lower intercooler pipe. Everythign else is stock on my evo IX.
I was told that upgrading to a 255 Walbro fuel pump would help me Attain higher boost levels on my tune. I was actually told to get a Walbro fuel pump and some sort of boost controller. But i can only afford the Fuel pump for now and cant afford to stuff the boost controller in too because of my budget.
Can someone please enlighten me. Should i throw in the fuel pump before the tune? How much would it help on the tune? (if any) Also would it even make a difference with stock injectors?
Old Apr 17, 2007 | 07:27 PM
spdracerut's Avatar
You'll definitely want the fuel pump in there before a tune. The walbro will 'over run' the stock fuel pressure regulator meaning that the fuel pressure will be higher with the walbro than compared to the stock pump. therefore, the fuel maps need to be retuned to compensate.
For boost, just tune the stock boost control system.
Old Apr 17, 2007 | 07:29 PM
sekula's Avatar
Yea, first though, I would def. get injectors and fuel pump as a set, the boost controller you can leave out if you don't have money, but the fuel pump is important along with the injectors, because for the tune, they will play around with fuel maps and timing maps and you need to be sure that your injectors and fuel pump can pump what GST is gonna demand from your car via tune. If I would've been you, I'd use the Greddy Intercooler money for injectors, pump, and mcb....lol, those are a lot more important and the stock core can handle a good amount of power.
Old Apr 17, 2007 | 07:37 PM
Dead-Man Inc's Avatar
Injectors on stock turbo ??
i say no ! ..
you'll need only a walbro + mbc n boost cauge. and u're set
theflyho's Avatar
Thanks for the input guys i definetely think ill be picking up the walbro fuel pump tommorow now. I just dont know about the injectors now...
Yea the greddy intercooler was actually a given to me by uncle who used to own an evo 8. So i was jsut slapped it on there.
thanks for the input again!
Old Apr 17, 2007 | 07:40 PM
theflyho's Avatar
Actually come to think of it i cant fit injectors into my budget anyway... haha
Old Apr 17, 2007 | 07:49 PM
sekula's Avatar
i say no ! ..
What? If you plan on running more than 19 psi for example like 26 on race gas or like 22 on pump, your motor is gonna inject more fuel to compensate for the more boost and you want like 660's for stock turbo with fuel pump, which is what I use and I run about 27 psi on race gas and it's perfect. Basically, you want to be safe if your gonna be using more than 19 psi so you don't max out your injectors and have a duty cycle of 100%, because that's NOT GOOD for the motor
Evo Pete MTL
Lancer Engine Management / Tuning Forums
22
Sep 5, 2012 10:14 AM
crf inc.
Lancer Aftermarket Forced Induction Tech
30
Dec 27, 2009 11:03 PM
vegasevo9
16
Feb 24, 2009 03:41 PM
dbsears
40
Mar 8, 2008 06:35 AM
DSMEVOLUTION
Aug 22, 2006 08:24 PM
