ACD and Anti'lock lights blinking
Old Apr 18, 2007 | 06:48 AM
gvillevo's Avatar
Don't know if this is normal, but when I hook up my OBDII cable, (just got it) the lights for the different settings of the ACD all blink together and the Anti-lock light also blinks. This only happens when I plug in the main connector and will stop when I take it out. Just wanted to know if this was normal or not.
Old Apr 18, 2007 | 08:10 AM
Pr3z's Avatar
Not normal if your speaking about a Tactrix cable.
Old Apr 18, 2007 | 12:07 PM
yikez's Avatar
just hooked up my cable and didnt notice anything like that.
try hooking up the cable before putting the car on the pre-start position.
are you sure you are using the right cable?
Old Apr 25, 2007 | 03:08 PM
TylerO@WORKS's Avatar
Interesting, they do that when we hook up our MUT II scan tool...
Old Apr 26, 2007 | 06:16 PM
gvillevo's Avatar
Yeah, didn't have any problems logging or pulling the map from the ecu. Going to be reflashing it either tonight or within the next couple of days so I'll see if it works.
Old Apr 26, 2007 | 08:33 PM
fastrob691's Avatar
I hooked up my cable and logged for the first time today and noticed exact same thing, as soon as I reach say 2-3 mph it stops blinking
Old Jun 23, 2007 | 08:17 PM
sharkm87's Avatar
Hey i have this same exact issue....whats the verdict?
Old Jun 23, 2007 | 09:22 PM
TunerHead24's Avatar
well i work for nissan and when we use the consult 2 (dedicated scanner) while its loading abs, cel, and airbag light up one at a time, maybe its normal....
Old Dec 4, 2007 | 08:58 PM
Boost3dxEvO's Avatar
Bringing this back from the dead...
Mine started doing this tonight and had the Tactrix Cable plugged in... so I'm guessing its just something that is normal....
Old Dec 6, 2007 | 09:37 PM
lemmonhead's Avatar
oh no that means its a tinking time bomb, boooom
just kidding, its normal. all the lights blink to let you know its connected. it shuts off after you start moving 5mph or so.
Old Dec 27, 2007 | 12:29 AM
gvillevo's Avatar
The lights don't ever shut off on mine. Everything works fine, it logs ok and I can reflash just fine. Just never knew why it does this.
Old Jan 12, 2008 | 03:50 PM
gvillevo's Avatar
Anyone have any ideas?
Old Jan 18, 2008 | 04:51 PM
alicea8541's Avatar
The one I just bought is doing it too. I borrowed a buddy of mines cable and it doesn't do it. I couldn't download my ROM, just kept getting an error.
Old Jan 20, 2008 | 10:44 PM
PHI_HO1's Avatar
i got the same thing but the cable is all good the light is blinking but i can log and flash with it just find. after i drive my car it stop blinking.
Old Jan 21, 2008 | 04:18 AM
alicea8541's Avatar
Mine works now, warmed the car up and then I could pull the ROM off the ECU. Lights blink until car is doing about 10 mph and then they turn off.
