Need Help with E-Flash InformatioN!! Plz!
Old Jul 26, 2007 | 08:02 PM
kryptonitex's Avatar
I am going to install a set of Camshafts, o2 Housing, Tubular Header, Fuel Pump, MBC, and re-install my HKS RS Reloaded onto my evo.
I have never had a tune or flash before.
Do I do the logging before or after I install?
Can anyone please help me in the steps to do this in?
Thanks.
Jonathan.
Old Jul 26, 2007 | 09:26 PM
OneillEvo's Avatar
Id would do a log before the install, note the time and temperature. Then do install and do a log, try to be around the same time and temp. If not no biggie. Seef what has changed and what needs to be improved. Send it off to a email flash tuner, or if you think you can tune yourself, edit away. I am by no means an expert just letting you in on what I know.
Old Jul 27, 2007 | 06:29 AM
newbieEVO8's Avatar
OP go to the link in my sig.
Mellon has information out there to help you on your quest.
Old Jul 27, 2007 | 08:11 AM
Mellon Racing's Avatar
Hey Jonathan, as Brad mentioned, I have quite a bit of information at www.mellontuning.com about how the process works, what equipment is needed and it even has a video tutorial on how to use the software/hardware.
let me know if you have any questions and I'll be more than happy to help.
Mike.p
13
Mar 9, 2011 01:14 PM
Kanweezy
Apr 15, 2010 01:38 AM
evo_RS
May 8, 2008 09:43 AM
titaniumkingpin
Aug 16, 2004 10:53 AM
