is tuning required
Old Aug 10, 2007 | 02:11 PM
aceinthesky2002's Avatar
is tuning required
bought downpipe, test pipe, catback, licp, aem short ram, i want a reliable car, will installing these mods ruin my car overtime without a tune.
Old Aug 10, 2007 | 02:15 PM
kreionic's Avatar
Required is a strong word. Its highly recommended that you do. I would if I were in your shoes i would but I would say its required
Old Aug 10, 2007 | 02:30 PM
suekie's Avatar
maybe not required....but highly recommended as stated....your A/F ration might be off from the intake (gas mileage worsen??) But with getting your car tuned after installing those mods will yield you sooo much more HP...
Old Aug 10, 2007 | 02:35 PM
1320 Engineering's Avatar
you will want a tune if you want your car to get more than 150 miles to a tank with that intake
Old Aug 10, 2007 | 02:51 PM
TouringBubble's Avatar
your AFR's will be all over the place at WOT without a tune, but I think you'll still be in the safe area since the cars run so rich stock. You'll be a lot happier after a tune, but it's not necessary.
Old Aug 11, 2007 | 03:55 AM
thanks
thanks for the tips guys, i'm going to definetly look into tune.
Old Aug 15, 2007 | 12:41 PM
Mellon Racing's Avatar
I agree and those mods aren't going to do much for you without a good tune to make the most out of them.
Old Aug 15, 2007 | 12:47 PM
SilverStreak's Avatar
^Exactly! You don't have to tune, as you will run rich with those mods. I had similar mods to start and ran without a tune. I was OK, until the weather got really cold, at which time I began to hit fuel cut. I not only noticed HUGE performance gains after the tune, but the car also ran better. It is well worth the money. Get a tune, especially with that AEM intake.
Old Aug 15, 2007 | 01:05 PM
rsalicrup's Avatar
Okay this answer some what one of the questions I had. So if the op doesn't mind me jump in here and asking this. I know once you get to turbo upgrades and stuff like, you will neded to a tune, but beside that. When is a tune actually required? Is there a site, link, etc where I can read the recommended steps to mod/tune an EVO some where? Thanks
Old Aug 15, 2007 | 01:12 PM
UT_Evo's Avatar
Mod, tune, mod, tune, mod, tune... there's the steps rsalicrup... tune after you do anything to the car. Like they said, not required, but do it anyway otherwise you won't have a properly running car.
Old Aug 15, 2007 | 01:16 PM
I would seriously analyze your modding goals before you tune. Once you get past the turbo-back exhaust, most any other mod would benefit from a tune. It would get expensive to continuously retune your car, so figure out what your mod goals are, wait until you can afford to get most of what you want installed, then get your car tuned. Warrtalon offers a Buschur setup that guarantees HP gains. Take a look at his offerings. They are an excellent starting point and allow you to achieve what most people would desire for a daily driver. Other than that, there is no specific information that I have found pertaining to exactly when a tune is "required."
Old Aug 15, 2007 | 01:23 PM
In all honesty, a tune isn't ever "required." But, nearly any power mod you do will change the way the car runs. The factory maps are forgiving and you will likely not run in to any bad problems. The most annoying issue you might see is a rich condition at idle after an intake install or a dirty bumper after exhaust is changed. The car will run safely with out a tune ... it just won't make nearly as much power.
Old Aug 15, 2007 | 01:29 PM
rsalicrup's Avatar
Cool info. Now, I have expirince with the Power FC since I had it on my FD. Would this be the best choice for an EVO though? Would that change the car to speed density? Also what is up with cams? I keep seeing hem on pretty much ever power package I see? I don't want to make a HP monster, just something fast for daily driven, goal would be 11s.
Thanks again
Old Aug 15, 2007 | 01:39 PM
11's on pump or race gas?
Old Aug 15, 2007 | 01:54 PM
rsalicrup's Avatar
sorry on 93.
