power fc (map sensor)
Old Aug 22, 2007 | 01:38 AM
haseeb's Avatar
hey im running power fc d jetro wid a 3 bar map sensor and my boost is 1.9 bars with a gt35 r turbo .
2.3l jam short block is goin in now and ill be running more than 2 bars of boost ,all i wana know is that wich 5 bar map sensor shud be compatible wid the d jetro ?
i need a 5 bar map sensor for my power fc now .
thanx
Old Aug 22, 2007 | 03:52 AM
94AWDcoupe's Avatar
I would choose the greddy 4 bar sensor from the e-manage ultimate. It will be good to 42psi. The 5 bar is more expensive and the loss of resolution is excessive if you are not needing 57psi map. The 3.5 bar would be good as well. Thats good for 35psi. No matter which one you use you have to enter the new voltage numbers yourself. You would have to raise the boost manually and measure the voltage at the sensor for each boost level.
Old Aug 22, 2007 | 09:00 AM
haseeb's Avatar
hey thanx for the help .i might get aem 3.5 bar map sensor .
ZU BA
18
Jan 24, 2017 11:22 AM
Fas4dr
21
Jul 28, 2016 04:22 PM
Llew
May 8, 2013 06:56 AM
evobanjo
Sep 15, 2010 12:55 PM
DYE-04
Dec 31, 2008 12:48 PM
