wideband vs afr meter
If i just want to know if i'am leaning out would a afr meter be good enough instead of spending 275ish for a wideband?I have evoscan so i'am doing all my logs through that .
By AFR meter do you mean a gauge that runs on the stock narrow band sensor? A wideband will of course be the best way to go. The stock O2 sensor jumps in nearly .5 AFR increments and is barely useful as a tuning tool. If you are tuning, a wideband is essential.
The LC1 is under $200, it's a no brainer, if you self tune and you by nothing else for your car, buy a wide band.
Forget intakes, forget cams, forget BOVs, get a wideband !
http://www.innovatemotorsports.com/products/lc1.php
MB
MB
wirespeed
Jul 6, 2008 12:30 PM
ciclon1
11
Nov 30, 2004 05:04 PM
