hp gain and tuning
Old Nov 12, 2007 | 05:54 PM
blackoutVIII's Avatar
hp gain and tuning
so i just got my cat back and downpipe. How much hp increase should i expect before a tune? Do I really need a tune?
Old Nov 12, 2007 | 05:56 PM
Evo_Jay's Avatar
Yes, you always need a tune.
Old Nov 12, 2007 | 07:14 PM
evolness's Avatar
I don't think its anything significant unless you get anything else done
Old Nov 12, 2007 | 07:53 PM
does the car run lean or rich without a tune and my mods?
Old Nov 12, 2007 | 07:56 PM
tripperfx3's Avatar
It'll still be running rich, but a tune will get you gains and lean it out. It'll also reduce knock as even from the factory you'll get knock. Just buy a Tactrix cable and contact either Mellon or Jestr.
Old Nov 12, 2007 | 07:58 PM
electricevo's Avatar
You will be hitting different load cells In your map that have less timing and more fuel that could potentially make you lose some grunt.
Your spool will still be quicker, and the car will be louder, but dont let that fool you. The car should be safe AFR wise, but you will maximize your power (and ease your mind) if you get tuned.
Good luck man
Old Nov 19, 2007 | 12:30 PM
hokiruu's Avatar
this is my dyno from Friday. Not a before and after dyno of the TBE, but a dyno of TBE only, then TBE with a tune:
https://www.evolutionm.net/forums/sh...highlight=dyno
As you can see, it's worth getting tuned. No you don't NEED a tune, but you will not see the maximum gains from your mods until you get one, and that's the main purpose of the exhaust in the first place.
Old Nov 23, 2007 | 04:03 AM
Mellon Racing's Avatar
thanks for the referral
Old Nov 23, 2007 | 04:05 AM
yes, you need to get a tune because now you're moving more air through the engine than before and hitting some load columns in the timing map with negative values.
If you haven't already, pick up a manual boost controller to compliment the new exhaust system and a k&n drop in air filter.
then get it tuned, most of my customers pick up 30-50awhp.
Jonno99
Apr 9, 2016 06:41 AM
StealthIX
75
Aug 17, 2010 06:53 PM
GOKOU
20
Aug 5, 2005 10:03 AM
skibum
Jan 27, 2004 07:05 PM
