twin fuel pumps question
Full-Blown, I wanted my car to be E85 safe/capable. I cannot speak for the milage as I did it before my 35R build, I changed turbos/cams/fuel pumps/some other stuff all at the same time, that being said i get better mileage off of the 35R than the 30r....go figure.
Scorke
Scorke
I went with the Full Blown twiin pump setup. I use a pressure switch to tell the second pump when to come on so that it's not running all the time because I heard it was bad for the stock fuel lines to have that much pressure all the time going through them. I use an adjustable FPR not sure if its a NEED or not. Gas mileage is mostly up to how rich the tuner tunes your car.
Scorke
Scorke
p.s. Gas milage is most dependent on how the car is driven, tune makes minimal differences as long as cruising A/F's are similar.
Scorke
I am not sure, could be a number of things. I think that as you said i make boost later in the RPM range so I am not using more fuel when just cruising.
Scorke
Scorke
What presure switch are you using? Is the presure taken from a boost vacuum tube or some other way?
Scorke
Scorke, did you run out of fuel, then you went to a twin pump set-up, or was it just a precaution?
Np, it's called a hobbs type switch, if I can find who made mine I will try to find you the part number and or manufacturer. You can get them in tons of pressure ranges either open or closed without boost, I am running one that is closed until 10 psi then once the sensor reads 10 psi the circuit is open it allows the second pump to crank.
Scorke
Scorke
Looking to cover the big end of boost\ful needs for my 35r. I may not need it with a 2.3 due to it not spinning that high(RPMs). But if I do need the twin pumps, then I'll be ready. Using stock lines and stock fuel rail.
I think even with a maxed out 35R you are just scratching the surface of needing a double setup, on e85 though all that goes out the window.
Scorke
Do you know where you got this hobbs switch? I am looking for the same thing for my inline pump. I just cant find a normally closed one in the right PSI range anywhere.
