Can I ground my LC-1 to the ECU?
Old Jan 25, 2008 | 08:34 AM
  #46
Profoxcg's Avatar
BTW I wanted to say that I am now successfuly running 15.5-15-8 A/F in closed loop thanks my WB and your imput guys.
Old Jan 25, 2008 | 04:29 PM
  #47
Jorge T's Avatar
Originally Posted by mrfred
What's a "mini add a circuit"? Do you mean the fuse box by the driver or in the engine compartment?
This http://www.thompson-automotive.com/c...11/2559633.htm can be used on the driverside fusebox to get switched power. They are a lot cheaper in O'Rilley's or any well stocked autoparts store
Old Jan 26, 2008 | 07:09 PM
  #48
Jameson_IXMR's Avatar
Speak of the devil,
days after reading this thread my wbo2 took a crap......
Old Feb 1, 2008 | 08:02 AM
  #49
joedr's Avatar
EvoM Moderator
I agree 100%. If you are logging thru an ECU pin, then you should ground the signal ground to the ECU. The power ground should be grounded separately as per Innovate instructions no matter how you log the LC-1.
On the Evo, I wired the signal ground to the battery and the power ground to the chasis.
On my Civic where the ECU reads from the controller directly, the signal ground is connected to the ECU ground and the power ground to the chasis.
Hope this helps somehow!
If the LC-1 data are being logged via the serial cable, there is no need to attach the ground wire to the ECU ground. However, if the LC-1 data are being logged via the analog out wire attached to an unused ECU input (to my knowledge, no one with an Evo is doing this yet), then its necessary to attach the signal ground to the ECU ground so that the analog voltage has the proper reference ground.
Benja
Apr 12, 2011 06:07 AM
evo9_jdm
May 5, 2010 12:53 AM
mlocatel
May 1, 2009 11:18 PM
EVOLex
Jul 25, 2008 05:47 PM
saiyuke
Jul 6, 2008 01:13 AM
