GOT IT!!! Just installed
Old Jan 17, 2008 | 05:50 AM
turbo271's Avatar
Just installe the AP with the map 2 93 OCT. Amazing results...
Just one problem; I'm not boosting to 22psi. Only about 18-20psi.
I'm sure that if I was boosting more, I would be even happier. Anyone else have this problem?
Old Jan 17, 2008 | 07:13 AM
denny424's Avatar
Did ya install the boost lines?
Old Jan 17, 2008 | 07:25 AM
s2krn's Avatar
Did you check for boost leaks?
Old Jan 17, 2008 | 08:21 AM
turbo271's Avatar
NO, Stock
No, I don't know how.
Old Jan 17, 2008 | 08:24 AM
denny424's Avatar
Well now you know why you aint hittin 22!
Old Jan 17, 2008 | 10:42 AM
Chris @ COBB's Avatar
^^^ Ya, what they said.
If you are still running the stock boost control system you can contact me and I'll get you a set of boost lines with a properly sized restrictor pill for your elevation. While the lines are on their way to you, you'll definitely need to check the car for boost leaks. Here is a link to a document that should help you out:
http://www.cobbtuning.com/info/?ID=3481
Give us a call and we'll get you the boost lines. (801) 713-0035
Old Jan 21, 2008 | 12:02 AM
Dorikun's Avatar
Question, if I use the stage 1 no mods map, the one used to up performance w/out mods, do I need to worry about a restrictor pill and lines? I'm in TX...
Old Jan 30, 2008 | 06:15 PM
Dorikun's Avatar
is that a no?
Old Jan 31, 2008 | 08:06 AM
CPA5's Avatar
Originally Posted by Dorikun
is that a no?
I'm like 99% sure you do........Instead of waiting for us morons (used lightly) on the forum you should be calling cobb for the fastest responses
Old Jan 31, 2008 | 08:36 AM
Dorikun's Avatar
