Problems with Access Port
Old May 31, 2008 | 10:14 AM
  #46
josher8's Avatar
I think the AP has taken over control of my boost from the HKS EVC VI i have installed. The EVC seems to kinda 'restart' a couple times in the first 10 minutes of driving. I have adjusted the correction coefficient but the boost isn't hitting the higher boost levels I was capable of without the AP. Anyone know if I am missing something?
Old May 31, 2008 | 11:34 AM
  #47
Bunni34's Avatar
hey let me ask u something. When u install the EVC do u still have the stock control attached? or does it come with a bypass self controlling solenoid?
Old May 31, 2008 | 01:01 PM
  #48
josher8's Avatar
it comes with a new solenoid and the stock stays plugged into the ECU but caps on the ports. The SES light is on with the stocker unplugged (that took me a bit to figure out) LOL. ECV comes with a new harness that plugs in also. why do you ask? I am a newby to imports so I like to learn all I can
Old Nov 26, 2008 | 09:33 AM
  #49
SAMIV80's Avatar
That is what I did and it is fine
Old Jan 19, 2009 | 12:53 AM
  #50
cevo8's Avatar
accessport for evos
hello guys I am still thinking if I should get apv2 for my evo 8 as engine management because the map seems to be unstable unlike my 07 sti I been using apv2 and it works great specially the race beta with 100 oct and 93 oct maps and I am hoping that cobb will do the same like they did to the subies before I will consider buying one for my evo
Old Jan 19, 2009 | 11:09 AM
  #51
Rob@cobbtuning's Avatar
The APv2 is very stable for your car and every car we currently support. If you have any concerns, please let me know.
Thanks,
Old Jan 23, 2009 | 01:28 PM
  #52
UnReaL STi's Avatar
that isn't good i would send it back to cobb and confront them with that problem
Old Mar 15, 2009 | 09:36 PM
  #53
superman59us's Avatar
Is there any update on the boost problem??
I recently installed my AP with ACN Stage 1 Map and I am also getting only getting 1.0 -1.1 bar boost .. I took out the secondary restrictor pill and still getting the same boost..
So i called cobb to get vaccum line and hopefully that will fix it. But if its going to be the same as stock but with out the secondary restrictor pill i dont see why it would be different.
From what i have been reading in the forums they might have to send me a different sized primary pill if i still can't reach boost, if im not misstaken.
Old Mar 18, 2009 | 08:59 AM
  #54
Installed the cobb vaccum Lines last night . But I am still only getting 1.0-1.1 bar of boost...
does anyone have any ideas on what can be the problem?
Running stock intake, catback exhaust, and there are no leaks
Old Mar 18, 2009 | 09:08 AM
  #55
CDO's Avatar
CDO
Because you already had a problem this probably isn't the answer, but if you hooked the lines up backwards at the T intersection that's the kind of boost you'll see.
That's the kind of boost I saw anyway when I hooked them up backwards.
Old Mar 18, 2009 | 10:01 AM
  #56
CaliMR's Avatar
I had problems with my AP preloaded map not boosting correctly and being inconsistent. I had a protune done and the problem went away. Removing the pill and then later swapping out the hoses did a total of .1 bar increase in boost. No boost leaks, no stuck actuator, nothing wrong at all with my car.
Check for leaks then get it tuned by a reputable tuner and be done with it. It is worth the money to be done with the headache of trying to fix it yourself.
Old Mar 18, 2009 | 02:42 PM
  #57
There is a huge disparity from car to car when it comes to the Evo VIII/IX. Some cars are different enough that a custom tune will be required.
As a side note (Not saying your car is broken) we have seen several of the stock Evo turbos slowly die. The symptoms are loss of boost levels over time given the same wastegate duty cycle and upped levels of knock sum. From our experience, unfortunately, Evo turbos simply don't spontaneously explode. It's a slow painful demise.
Thanks,
Rob
Old Mar 20, 2009 | 12:41 AM
  #58
yeah that would make sense!!
I hope my turbo isn't dying.. well i 'm pretty sure its not .. because i was reaching 1.2-1.3 bar boost no problem before i installed the AP..
I installed the hoses correctly, the hose with the primary pill in it (with the yellow dot) goes to the j pipe and so on..
But i called Cobb again.. and they are sending me a different sized primary pill.. GREAT Customer service BTW.. hopefully this works.. if not ill get a pro tune way sooner than i was planning.
Old Jul 6, 2009 | 02:35 PM
  #59
The new restrictor pill worked like a charm!!!
My car now boosts perfectly fine!
Great customer service from Cobb!!
Old Aug 13, 2009 | 07:54 PM
  #60
cpunlamd's Avatar
Nice.
EvoDan2004
28
Oct 25, 2013 07:58 PM
evo unknown
22
Feb 10, 2010 04:41 PM
stimpy
12
Aug 23, 2007 10:04 PM
2literturbos
Jun 28, 2004 10:08 AM
ProStreetOnline
Evo 'For Sale' Exterior Styling
Apr 24, 2004 07:17 PM
