LC-1, XD-16 Error 2 (first use)
Old Jan 26, 2008 | 10:32 PM
Jameson_IXMR's Avatar
This pertains to the Innovative LC-1 and XD-16. (as there was no other section for this)
I wired everything up, used a convienent power and ground, I tested them, they are fine. I powered up with the sensor off, I get E-2 flashing permanently. Manual says that fine, I wait 20 seconds, power off and hook up sensor and leave it in open air. I turn power on, still E-2.
I have re-soldered every connection, verified the wires are right, the terminator plug is in where it should be. Im guessing sensor is bad or the LC-1. Any ideas to further troubleshoot untill Monday when I can get some support?
Old Jan 26, 2008 | 10:34 PM
EvoDan2004's Avatar
i might confuse you but there are 2 inputs and 2 out puts. are you sure there setup right?? also there is a blank plug that needs to be used as well.
Old Jan 26, 2008 | 10:39 PM
EvoDan2004's Avatar
here is what i got
disconnect sensor from the lc-1
turn car to the on position for 30 seconds. you should see E-2
then turn off car
reconnect the sensor to the lc-1
turn car to the one position till the wideband gauge reads between 20.7 / 20.9 blink o2
reinstall o2 sensor into exhaust pipe and start tuning
Old Jan 26, 2008 | 10:40 PM
EvoDan2004's Avatar
if my above post does not work you either did it wrong or its hooked up wrong.
Old Jan 26, 2008 | 11:45 PM
Oh no, I have had a great deal of "hands-on" time with a multimeter, and various board-level, and component logic gates. The power wires are solid, they rate at 14.2Vdc with a .2Vdc tolerance. The ground reads nothing over 0.00032 Ohms. The stereo linked triax connectors are connected as follows.
LC-1 Input - Terminator Plug (blank)
LC-1 Output - XD-16 Input
XD-16 Input(I mean output) - disconnected. (for use with serial cable to computer)
I have read through the serial/stereo cable, and everything is fine. There is either a faulty sensor/element, faulty LC-1 device, or I accidentally set some option or something completely strange that forces the E-2 code. I never get the coil warmup sequence or anything, and the sensor does not produce heat. Since the sensor is cold and the XD-16 is not displaying "- - -" indicating comm failure. I assume it is the Sensor.
Anything I'm missing?
Old Jan 26, 2008 | 11:48 PM
EvoDan2004's Avatar
XD-16 Input - disconnected. (for use with serial cable to computer)
go turn the car on and on the xd-16 gauge there is a button. push it 3 times real fast. what happens?? it should say cal or something. then push it 1 more time. then do the steps i said above
Old Jan 26, 2008 | 11:50 PM
Wicked E's Avatar
Evodan is like a god... Do everything he says or you'll be damning everything you ever did... Don't ask me how I know.
Old Jan 26, 2008 | 11:54 PM
EvoDan2004's Avatar
o crap. here we go again. dont get me started. HAHA
Old Jan 26, 2008 | 11:58 PM
Wicked E's Avatar
I've noticed lately that all the people that swear up and down their **** is correct and you tell them what to do right off the bat and they still swear their **** is right. Come to find out they waste 2 weeks swearing when they could have taken your suggestions for 5 minutes and had their **** working...
Some people...
Old Jan 27, 2008 | 12:03 AM
EvoDan2004's Avatar
ur gauge is wrong.
xd-16 output is the one for the cable for the laptop
swap the output for the input...
then reset the hole wideband. then do what i said above.......................... again
Old Jan 27, 2008 | 12:06 AM
Wicked E's Avatar
I <3 you dan...
EvoDan2004's Avatar
I <3 you dan...
HEHEHEHEEEH
Old Jan 27, 2008 | 12:16 AM
Oh a typo, I have it connected correctly. Yes the XD-16 out is for the laptop. Sorry about that. I already tried forcing a cal on it. I get the "Cal" flashes like it wants me to say yes or no. I agree with a press of the button and it goes straight to E2...
Thats..
10 Display - E2
20 Press Button x3
30 Display - CAL
40 Press Button x1
50 goto 10
Anything else I should check?
Old Jan 27, 2008 | 12:19 AM
Wicked E's Avatar
I'm stumped and dead tired... Let me sleep on this and hit you up tmw. I used to own the same gauge set up in a previous turbo car of mine so it's been a while.
EvoDan2004's Avatar
Oh a typo, I have it connected correctly. Yes the XD-16 out is for the laptop. Sorry about that. I already tried forcing a cal on it. I get the "Cal" flashes like it wants me to say yes or no. I agree with a press of the button and it goes straight to E2... Anything else I should check?
when you touch the o2 sensor to see if its hot are you touching the sensor part ''tip'' or the metal part that the wires are going into???
