Tactrix cable problem
Old Mar 23, 2008 | 11:19 AM
evoryne's Avatar
Hey guys this weekend i tried to flash my evo but for some reason the white part of the tactrix cable would not read my ecu, so i could not install my map. Has this happened to anyone else, could my cable just be broken? Any advice would be appreciated.
Old Mar 24, 2008 | 10:46 AM
lemmonhead's Avatar
sometime I had this problem, like the connector was not on perfect. I just take it all off and put it back in. then it works. but im sure you already tried this. i dunno have you continuity tested it.
Old Mar 24, 2008 | 10:57 AM
evoryne's Avatar
Yeah i have tested it on a couple different evos and the same thing. Could it be the programs on the computer need to be reinstalled?
Old Mar 24, 2008 | 10:58 AM
EvoBroMA's Avatar
are you connecting both parts of the cable?
evoryne's Avatar
Yes im connecting both cables at the same time.
Old Mar 24, 2008 | 03:48 PM
lemmonhead's Avatar
well if you tried on more than 1 car and same problem. then sounds like your cable is the problem some how.
