What knock count should make me worry?
If that 7 is consistent you need to address it. the IX pulls timing at even 1 count of knock, but it's not dangerous ... it'll just pull a degree of timing for a moment.
When i tune I can accept a few 1's in the log, but 2's and 3's are not acceptable for me.
+1 TB knows his ****!
Post up your log if you can. What was around the 7? 6's and 5's and so on? I had the same problem a few years back. Surprisingly (to me at least) 1 octane point makes a huge difference in tuning. Where I had 0's and a few 1's on 94 octane I had 6's on 93.
I have... As soon as they make it available in my neck of the woods, gonna make the switch! Although I believe I have read you need to upgrade Injectors to 1000cc's ! Its starting to grow in Cali, but more in NorCal. I think Arnold is trying to make it more available in SoCal... We'll see... 91 FTL
[QUOTE=nonschlont;5785780]I have... As soon as they make it available in my neck of the woods, gonna make the switch! Although I believe I have read you need to upgrade Injectors to 1000cc's ! Its starting to grow in Cali, but more in NorCal. I've heard there are a few place in SD as well... I think Arnold is trying to make it more available in SoCal... We'll see... 91 FTL
Hmmmm I 'll post the logs when I can. 7 is just very quickly and is surrounded by 5's and 3's. Glad to hear its not a horrible occurance.
Turned boost down a point or so and the knock is gone.
Knock has a higher probability of causing failure at higher RPM. You can't use the term "load" around here too loosely since it's both a variable the ECU uses and a measure of how hard the engine is working.
So, your example ... 3 counts isn't going to break anything. But, if you were to compare 8 counts at 3500 at cruise and 8 counts at 7000 and 21 psi, the high RPM, high boost knock occurrence is a much larger issue.
