can the ecu lose its reflash somehow and go back to stock form?
i ask this meaning can something have happened to make it go back to stock form after i've had it reflashed? the car has lost alot of power! i have no boost leaks, cat looks perfect, no engine codes, stock clutch catches torque unless its barely slipping somehow thats unoticable, the cars drivability is the same just less power. at the same time i felt power loss i noticed my boost only hitting 16-17 ( and thats even with a new boost solenoid) so i put the MBC, set it to 20 and it still feels almost the same.....
the butt dyno by more than just me ( multiple people) feel the loss of power. my dyno sheet shows the power and A/F's and dave at buschur said they seemed normal.... i dont know wtf to do now! i know something is wrong somewhere but i dont know what else i can look at the car only has 10k miles and had the parts on it for 7k.
i ask if it could have lost the reflash because unfortunatly i had underglow on the car and i just noticed the amp was exploded under the car and the fuse was blown..... this shouldnt have effected anything but i duno wat else to look at.
lol... does a computer lose all its information when its shut off.....
hmm i dont think so..
well thats what the ecu is a computer and no it wont loose any information... like tpphra says unless its flashed over
if you disconnect the battery the RAM part of the chip will be erased, but this doesn't contain code just variables.
so things like what current CEL's or fuel trims will be erased but fuel maps will stay...
gotcha its not a boost problem i boost checked it 3 times now, i've also put a bran new boost solenoid in and i still get the same results just now with a mbc i can run what it should be running but still no power. almost like the cat is plugged or something but thats not the case either...... is this a symtom of a turbo seal gone bad possibly?
deathtracks
21
Oct 24, 2015 11:01 PM
DrMerl
Dec 21, 2003 10:39 PM
