HKS EVC VI question!!
Old Jul 3, 2008 | 04:50 AM
RyongCE's Avatar
hello guys!
I have a HKS evc vi (latest version) and was using it just fine. And now, after I installed Tial external wastegate, it started overboosting. I heard somewhere there's a switch that I need to change ? Swing valve to poppet? But I don't unfortunately have the manual instruction and have no idea where or how the switch is. Can someone help!!?
Old Jul 3, 2008 | 05:20 AM
robbie2883's Avatar
usually you need to configure the hoses different for an external wg then you would for an internal but none the less hope this helps
2 seconds of looking and here ya go
http://hksusa.com/faq/?ID=1544
as well as the instruction manual
http://hksusa.com/faq/?ID=1647
Old Jul 3, 2008 | 05:22 AM
Evo Tengoku's Avatar
I am almost certain you have to do a full reset to be able to change SWING to POPPET in the initial setup.
Push the bottom button 3 or 4 times until it says AS7 "NO"
Hold the knob down till it blinks
Turn knob to "YES"
Press knob
**** this resets all settings on your EVC VI. ****
