No misfire, 0 knock, low timing advance???
I am trying to figure out why my car is only advancing timing like 5 6 degrees from 6k-7.5k. The car has 27k miles with mods in singature, the car has no misfires, it doesn't break up. I have pulled the plugs but they look ok, should I change the plugs? Even though the car doesn't misfire or break up, can the spark plugs be the issue?
yes, the knock count is 0. I am trying to figure out if it is the spark plugs that is limiting the timing to 5 degrees, by replacing the spark plugs I am thinking it will fix this issue and allow to run normal set timing.
johnashton11
11
Sep 13, 2019 01:23 PM
Enjoi926
May 31, 2017 06:47 PM
lopillo_evo
Oct 29, 2011 08:24 AM
