What heat range plugs should I be using?
Old Nov 10, 2015 | 02:55 PM
D1andonlyantman's Avatar
Hi. I've had an ongoing misfire/cutout issue for a while now and I've been told it could be because I'm using the wrong plugs, and i was hoping someone could confirm what plugs I should be running. Basically when I bought my IX it had a few usual bolt-ons (intake, manifold back exhaust, standard ebc) with my car remapped to 386bhp and not too long after I bought it I noticed sometimes it kind of misfires or cuts out for a split second when at WOT in 5th or 6th and then carries on as normal. It doesn't happen everytime but if I keep ripping through the gears it will happen. I've stuck in some fresh ilfr7h plugs gapped to the standard .5mm and recently fitted a COP kit thinking maybe the spark was struggling with the 27psi boost (according to torque app) but it's still no better. Someone has told me it could be because I need to upgrade my plugs but I just wanted some confirmation before I buy yet more spark plugs.
Any opinions appreciated
Thanks
Old Nov 10, 2015 | 03:19 PM
Bhsj13's Avatar
you need to gap it down to .022 or so. with a 1/2 step colder than stock plug imo.
Old Nov 10, 2015 | 03:39 PM
I'm guessing there's a bit of inches vs millimetre confusion here because .022" is actually .55mm which is basically what I'm running when you say colder would that mean move up to the 8 heat range rather than the 7?
Old Nov 10, 2015 | 04:12 PM
Pal215's Avatar
Based on your power level and setup I would switch over to Denso Iridium IKH24 (5346) and gap them to .022" These are a step colder plugs that offer great all around performance when running high boost. I had the same issue that you are describing at around the same boost pressure until I switched over to these with a 0.022" gap.
-pal215
Old Nov 10, 2015 | 04:26 PM
OK mate thanks. I just wanted to hear it from someone who wasn't trying to sell me the plugs lol I'll get some ordered
Old Nov 10, 2015 | 06:45 PM
Bhsj13's Avatar
let us know how it goes!
Old Nov 11, 2015 | 02:02 AM
Will do, thanks for the help
Old Nov 11, 2015 | 04:08 AM
evo8426's Avatar
-pal215
I run 34psi on ILFR7H with .022 gap making well over 500whp. I've said it time and time again over the years, you do not need a colder plug on the 9s. Every 9 local to me that I've tuned are also running over 500whp on the same plugs. All running factory ignition.
Old Nov 11, 2015 | 12:53 PM
Hrm, good info there but not what I was hoping to hear obviously. I'm tempted to give the colder plugs a go anyway seeing as pal 235 said it cured a similar problem for him purely because I've got no other ideas, unless youve got some idea as to what it might be?
TTP Engineering
Apr 8, 2009 01:20 PM
highhats
Jan 6, 2009 09:36 PM
Davo
May 28, 2008 09:11 AM
SlowCar
Dec 5, 2006 01:55 PM
Axiom-Power
83
Sep 29, 2006 01:58 PM
