Access port on E-85 fuel tune
Old Sep 20, 2008 | 10:40 PM
evossl's Avatar
Anybody has done this? One map for E-85 and another for 91 octane.
Your feedback would be appreciated.
Thanks
Old Sep 21, 2008 | 09:48 PM
evossl's Avatar
Anybody? I guess I will not invest on the hardware.
Old Sep 22, 2008 | 12:57 PM
rEVoLed's Avatar
I used the race tuner to create a e85 map and it has work good as of right now. They had the injector scaling backwards I believe and I will have to verify that.
Old Nov 28, 2008 | 11:15 AM
Jim in Tucson's Avatar
E85 Ftw !!!
I think if Cobb included an E85 map it would significantly add to the value and distinctiveness of the AP. It would allow anyone anywhere to simply buy the AP, load the E85 flash, fill up with E85, and add significantly to the power output.
Obviously, this would be a Stage 1 E85 tune and not be a max tune. (A Stage 2 E85 tune may require a fuel pump and larger injectors.) Certainly, there must be enough IDC in the stock injectors to make an E85 map a worthwhile addition to the AP for the X. Suddenly Cobb would have something no one else is offering!
Old Mar 16, 2009 | 05:29 PM
brian94ht's Avatar
If only they were listening....?
Old Mar 16, 2009 | 06:11 PM
GST Motorsports's Avatar
You would max out the stock injectors very quickly on even a stock evo 8/9 with E85 and boost control.
To the OP, yes you can tune E85 with the accessport.
onefast2gdsm
Dec 26, 2016 02:15 AM
Yiyo
Aug 8, 2012 04:29 AM
bbyevo8u
E85 / Ethanol
Jul 24, 2011 02:05 PM
Dragking2189
Dec 27, 2008 01:30 AM
Dragking2189
38
Nov 30, 2008 02:46 PM
