e85 gauge
Old Mar 22, 2011 | 03:28 AM
bbyevo8u's Avatar
e85 gauge
is it important to use a e85 gauge when using e85?
Old Mar 23, 2011 | 10:11 AM
dek0026's Avatar
you can buy a tester from summit for like 15 bucks.
if you're talking about running a setup similar to the flex fuel vehicles and using a gauge to read your fuel mix, i'd imagine that costing quite a bit of money.
Old Mar 24, 2011 | 02:41 AM
umopp's Avatar
Not sure if I'm understanding your question correctly but if you're referring to using a gauge to see the actual ethanol/gas mixture then it might be a good idea to have a gauge of some kind. Since not every tank of e85 will have the same mixture, it could have an effect on how your car runs if you have a tank of it where the percentage of ethanol in the tank is lower.
Old Mar 24, 2011 | 04:29 PM
bbyevo8u's Avatar
yes your rite! thanks
Old Mar 28, 2011 | 11:26 PM
jackbenimbo's Avatar
i also think that would depend on where you live, i can see why you would need it in really cold winters over in the east but places like ca....not so much..most of the gas stations ive seen never go lower than 80...75 the lowest
Old Jul 24, 2011 | 02:01 PM
Angel Evo's Avatar
are you talking about the little bottle ?
Old Jul 24, 2011 | 02:05 PM
erald01's Avatar
or maybe just maybe you can use an a/f ratio gauge ..the little bottle btw is to test the ethanol mixture.
evoinit
E85 / Ethanol
19
Sep 20, 2018 05:12 PM
theblackbeast11
Mar 16, 2016 12:49 PM
cbr1000
Oct 28, 2010 01:07 PM
05EvoVIII
Apr 5, 2009 08:09 PM
Dragking2189
38
Nov 30, 2008 02:46 PM
