E85 hurting fuel injectors
Hey guys im switching over to E85 in the next couple weeks and im unsure on what injectors to go with. i have read that E85 is really harsh on injectors and can really mess up the spray pattern. I have also seen that sum company's dont warranty there injectors when E85 is used... What are you guys running with E85 and how is everything going so far?
thanks guys
thanks guys
What turbo are you running or planning to run. I'm on FIC Bluemax 1450's and although a little tricky to scale they do work...
PTE 1600's won't idle on pump gas. The FIC Bluemax 1450's will.
https://www.evolutionm.net/forums/ec...max-1450s.html
I know what size injector i need. I just dont know what brand to go with....im going to try n find the thread that a guy started when his injectors went bad from using e85 and stick it in here so you guys know what im talkin bout.
get in touch with Mike @ AWDmotorsports, he has some high power cars of himself and some of his customers running E85, he as of right now is one of the most knowlegeable gear heads in the community with E85.
Here is the link to what i ma talking about.....https://www.evolutionm.net/forums/ev...85-beware.html
i have also seen people complaining of the injectors getting clog with a tar like gunk on the tips
RSGuy
28
Apr 7, 2011 04:34 PM
