E85 and making power.
Old Mar 10, 2011 | 06:44 AM
Guru Johnson's Avatar
Hey guys,
I hate to ask a stupid question but here goes.
I always read E85 makes it's best power the closer to 11.8 - 12.0 you get?
So my question is .. If I'm too rich, say 11.2 afr WOT at 24psi and I make 360hp .. Will that actually go up any if it gets leaned out but still at 24psi and no change to timing?
Thanks for any myth debunking that may come.
Old Mar 10, 2011 | 06:45 AM
05blue8's Avatar
Every car is different but to generalize, yes unless you're already past mbt. My car loves 12.4-12.7 on e85 and actually knocks if it goes richer into the 11's
Old Mar 10, 2011 | 07:20 AM
Long story short..
360hp at 11.0 afr wot and 24psi on a dyno and 371hp from virtual dyno ..
(1st result was 369,
second result was 371,
third result was 369)
However after leaning out to 11.7 afr wot (still no knock either btw) VD said I did
(1st result was 381,
second result was 383,
third result was 383
all virtual dyno tests were on a highway from 2500rpm to 7500rpm.
But I wanted to make sure what I read many moons ago about leaning out to 11.8 to 12.1 yields the best results with E85
Thanks!
Old Mar 10, 2011 | 08:09 PM
Jim in Tucson's Avatar
Originally Posted by Guru Johnson
Now this guy Diirk is good tuner. He knows his stuff. We put this thing on the dyno with the new turbo and nothing we do gets this thing over 24psi .. but he left me rich .. I'm talking 11.0 at WOT
Diirk knows his stuff about tuning; he has an excellent reputation. I would not second guess him w/o first discussing your situation with him. Did you ask for an on-the-edge drag tune? Or an extremely safe road-race tune? Or a middle-of-the-road street tune?
It sounds like you are wishing you had a drag tune, but may have not asked specifically for it. If you don't ask, you may very well end up with a more conservative tune than you wanted. Talk to your tuner. That's why tuners have ears, so they can listen to their customers!
Old Mar 22, 2011 | 07:48 AM
mrfred's Avatar
my experiene is that richer than 11.8:1 it has greater knock tendency, and leaner than about 12.2:1 it starts getting softer.
Old Mar 22, 2011 | 07:50 AM
PeteyTurbo@KHC's Avatar
Or he was tuned in the summer and is currently running winter blend
Old Mar 23, 2011 | 10:31 AM
06RedRalli's Avatar
^this is possible...
Old Jul 24, 2011 | 02:06 PM
Angel Evo's Avatar
I can put more boost pounds to be more close to the 12.0 add more hp and dont need to do nothing else to my motor or ecu ?
tscompusa
Oct 6, 2016 10:55 PM
AcePitcher11
32
Dec 26, 2008 03:33 PM
Gsxtremedsm
E85 / Ethanol
Aug 26, 2008 10:15 PM
PeteyTurbo
Jun 8, 2008 08:41 AM
AMS
29
Mar 22, 2007 10:06 PM
