loosing power plzz plzz help
hey guyss.. im back home in SriLanka.. n thought ill build my evo 3 i knopw it sucks to go form a evo 9 to a evo 3 but evo 9s here costs ab 8.5 million tats ab 85k..anyways here s da prob .. after the build up i can feel im loosing a lot of power coz da car dont feel quick n dont pull as hard as it use to.. here s da mod list
Je pistons 8.8:1 std bore from Buschur
eagle H rods
BR dual valve springs & Ti retainers
stainless steet std valves
255 fuel pump
fule pressure regulator
custon 2.5 inch IC pipings
custom 3.5 inch straight exhaust
arp head studs
removed the balance shafts
steel head gasket form buschure i think its 1.6mm
act 2900 lb clutch & fidanza streel flywheel
megan ext manifold
turbonetics raptor bov
TDO6H 20g turbo
780cc injectors
BR boost controller
tuned chip form coast to coast motorsports UK
before doing anything i ran the car wit 780 cc injectors & 20g turbo n da car really opened up around 20psi but now it feel slower than stock
i checked for compression it was around 140 + in all 4 & the funny thing is my wideband say A/F at WOT is at 10.. but i took the turbo & ext mani off to see they looked soo clean as if i was running really lean.. PLZZZZ PLZZZZZZ help guys..
eagle H rods
255 fuel pump
arp head studs
megan ext manifold
TDO6H 20g turbo
780cc injectors
BR boost controller
