New Power FC Install
Old Sep 25, 2008 | 10:46 PM
alex750803's Avatar
Smile New Power FC Install
I just installed my Power FC on my Evo 6 RS. I let the ECU do its 30 minute learning procedure after which the car drove ok, although I think its cuts out a little to easily when at idle and I engage the clutch. I actually have to blip the throttle to move off smoothly most of the time. I increased the idle value from 850rpm to 1000rpm but it did not help much. I am very new to tuning and have some questions I would like answered if possible.
1. Do I need to manually input my current Injector info (using 560cc) into the PFC and how do I enter this data correctly?
2. My Exhaust Manifold glows after a hard run. I don't have a AFR Gauge/Pyrometer as yet, I suspect that I am running lean though and need to upgrade my injectors, how can I check this for sure?
3. How can I see and change my Injector info e.g to see if my Injectors are running at their Maximum or if they have room for increasing their operating settings? I can't seem to find that using the Hand Controller.
Thanks for the help.
Old Sep 25, 2008 | 10:59 PM
evo420's Avatar
good luck be very carefule you NEED a wideband afr sensor
Old Sep 27, 2008 | 04:05 AM
alex750803's Avatar
Smile
My Wideband Sensor and AFR gauge are on their way. I should have them hooked up by next week. Anyone else has any advise to share?
Old Nov 21, 2008 | 04:15 PM
gtm_maxwell's Avatar
Sure I am using a PFC with Wideband and Datalogit for Logging.. once u have this 2 items and some knowleadge of tunning(A/F vs Timing vs knock...etc) than u are ready to tune..
If u don't have a Datalogit is better that u try to do setting on a low loading point first. and try to make sure some one help u to do the driving...Hehe
Old Nov 25, 2008 | 08:42 PM
lilevo1's Avatar
If anyone is lookin for a powerFC for an evo8 pm me
i have one for sale..600 shipped thats the powerFC AND the power commander
Old Dec 25, 2008 | 02:04 PM
Edo Performance's Avatar
if you guys need any tuning help, just let us know. we can help your Power FC
EvilTechnology
Jun 24, 2015 09:22 PM
David Buschur
Apr 20, 2012 07:59 AM
Smurf Rocket
24
Oct 22, 2010 06:00 AM
smartbomb
Dec 24, 2007 04:49 PM
evopower1021
Jun 13, 2007 09:58 AM
