AEM Tru Boost controller
Old Oct 6, 2008 | 08:39 PM
Wick3d3vo9's Avatar
ANyone have any experience with these?? I heard so many different things about them. are they good or Not good??
Old Oct 6, 2008 | 08:59 PM
keithano's Avatar
rocking them with no problem. Just love them, doing a great job.
Old Oct 6, 2008 | 09:03 PM
Wick3d3vo9's Avatar
I already have a defi boost gauge, I was just wanting it for the ebc. Is it worth it?? I have the Aem wideband
Old Oct 6, 2008 | 09:28 PM
Wick3d3vo9's Avatar
does anyone know if they make a gauge that connects to the obdll port?? similar to like a scan gauge??
Old Oct 6, 2008 | 09:35 PM
IHEARTevoIX's Avatar
i dont think its worth it if u already have a boost gauge.. a manual boost controller should be efficient enough for u..
the purpose of the tru boost is having a boost controller plus gauge in 1.
and youll save a lot more money going to the MBC..
anyways to answer your question.. the aem tru boost works perfect for my car.. very easy to use and set up.. and its easy for me to switch between race and pump gas maps.. all i have to do is hit a button on the tru boost and flip a switch in my glove department. its easy as that.. havent had a problem with it since i installed it.. would recommend to anyone!
Old Oct 6, 2008 | 09:43 PM
blackchiney-8's Avatar
what switch do you flip in the glove box, is this attached to some separate controller, explain for me here as i have been thinking of switching from the greddy spec2 to this
Old Oct 7, 2008 | 02:43 PM
Wick3d3vo9's Avatar
I have the DEFI 3 gauge setup, which includes the boost gauge. If I wanted this just for an ebc would it be worth it?? I have an AEM wideband and these 2 would look good together on a dual pillar. I don't car if it reads boost I just want it for an electric boost controller
Old Oct 7, 2008 | 03:37 PM
deuce329's Avatar
I'm curious to what switch you are referring too. I'm looking into the aem tru boost as well. Can you run 3 boost settings?
Old Oct 7, 2008 | 03:38 PM
04gsna's Avatar
switch is prob for map switching on the ecu, not related to tru boost
Old Oct 7, 2008 | 03:44 PM
keithano's Avatar
Tru-boost can give you the options to switch through 2 pre-set boost map.
You can tune Map A for 24 psi, and Map B for 18 psi, and then switch through these two.
Old Oct 7, 2008 | 04:07 PM
i know i gonna get flamed for this but any of you guys know anyone selling theirs or might be willing to trade for a profec b spec 2
Old Oct 7, 2008 | 04:14 PM
04gsna's Avatar
I have one
Old Oct 23, 2008 | 05:07 PM
ya the switch is for map switching on the ecu.. its just easy to change boost levels with the truboost.. litterally with the tap of a button
Old Nov 17, 2008 | 12:10 AM
buddah2006's Avatar
i wana set my boost to 22psi, but im dont know what to set the settings to. does anyone kno what to set the SPr, FUL ,SCb ,SCr to cause i need help
Old Nov 17, 2008 | 11:51 AM
djuntouchable21's Avatar
awesome lovin it ... so far so good
