Evoscan problem
Old Jan 4, 2009 | 12:07 AM
shuttlegoose's Avatar
Evoscan problem
Hey so i finally got a new laptop to tune with and i was just installing all the necessary software such as evoscan .99 and ecuflash. I went out to take some logs and evoscan would successfully connect, but then timeout and reconnect repeatedly. Im talking like 50 times and going at a very fast pace. I checked my com ports and everything was in order, i feel like there is something still wrong (obviously). Im also using an innovate lc-1 to log afrs. thanks again.
Old Jan 4, 2009 | 12:16 AM
nonschlont's Avatar
If you dont have a WB installed in your car, then uncheck "External WideBand A/F ratio".
Old Jan 4, 2009 | 01:15 AM
no i have a wideband installed, i believe the error is coming from the tactrix usb because it keeps timing out. any ideas?
Old Jan 4, 2009 | 03:31 PM
PPM's Avatar
PPM
Cable could be bad. You might want to uninstall the device in device manager and re-install to re-install your driver. It definitely sounds like a hardware error. The cable could have gone bad, but I would check your drivers first. If it is not the driver, re-install evo scan and try again.
Old Jan 5, 2009 | 03:25 PM
anyone else??
foxbat
Jan 9, 2012 03:42 PM
evo jason
Jan 7, 2012 04:25 AM
magyar86
Mar 3, 2009 09:29 PM
evo8dad
Jan 31, 2009 03:48 PM
BigBallin
Aug 15, 2007 12:12 PM
