Tuning a Red with cams....injectors?
Old Jan 27, 2009 | 02:37 PM
EvoDom's Avatar
waddup evom, looking to order the red within a few months, ordering kelford 280 / 272 cams with manley springs and retainers next week.....when i go to tune the car what do you FP Red owners use for injectors?
i was going to throw like 850cc injectors but im afriad they wont flow enough fuel for the FP Red and 280/272 cams.
should i just leave the 850's or jump up to like a 950cc or 1000cc?
will the 850's flow enough for my set-up or no?
thanks guys im afriad the 850cc is my minimum like im going to max them out
any info is great
Dom
Old Jan 27, 2009 | 02:45 PM
evoixbri's Avatar
880cc and 93 pump and you straight bro.
Old Jan 27, 2009 | 03:13 PM
EvoDom's Avatar
haha thanks brian,....havent heard from you...how you ben
anyone else have info?
Old Jan 28, 2009 | 04:56 PM
EvoDom's Avatar
i need more help. will 880cc injectors be fine if i tune on q16 also? or will i run out of fuel?
qucik response lol
Old Jan 28, 2009 | 04:58 PM
brodienuchies's Avatar
880 is good for pump. But if you add METH or Race...may need bigger to get the max out of the turbo...
Old Jan 30, 2009 | 08:25 PM
~BoOsTeR~'s Avatar
go 1200's. Room to grow into a bigger turbo or different fuel.
Old Jan 31, 2009 | 05:36 AM
PeteyTurbo's Avatar
your 850's should be fine for a gasoline tune..If you run race gas you will not need as much fuel at the same boost level..
Old Feb 3, 2009 | 01:58 PM
RunRunRun's Avatar
I would say 1000cc or 1200 just to be safe and so you have room if you ever run race gas or meth or something.
Old Feb 3, 2009 | 03:04 PM
jezzy101's Avatar
Veteran: Marine Corp
PTE 1000's and you will be good
Old Feb 4, 2009 | 03:26 PM
EvoDom's Avatar
just ordered precision 1000cc thanks for the help guys
Old Feb 4, 2009 | 03:28 PM
4WS Tuning's Avatar
Meth will actually lower his IDC. Youre 110% correct about the race gas.
I always so bigger the better with injectors. Scaled properly you wont notice any difference over stock.
Cheers!
Old Feb 4, 2009 | 04:20 PM
holiday63's Avatar
atleast 1000cc, if your set up or fuel use changes you'll be safe. no point in buying injectors twice
Old Feb 4, 2009 | 04:59 PM
EvoDom's Avatar
^^ exactly and i was going to just get the 850cc's, but with me maxing out the cars potential on 93 pump, that will be pushing the injectors to its fuel potential because i dont have meth yet, if i had meth i would be ok because my IDC would be lower and i can just keep the 850's, but me with the 1000cc's will give me a lil le-way to tune with and then when i do the meth in 2 months i will still be ok
