Error: No response from vehicle ECU
Old Feb 7, 2009 | 10:29 AM
555R's Avatar
yeah had a weird issue only made 6psi but then found out my bov came apart...i unscrewed it too far to lower the preload and it popped off...
one prob found then couldnt get the evoscan to communicate with the ECU and get rid of a code...then used the actron and found our wonderful P0300 random misfire caused by the bov popping apart
code erased...end of story
time to buy an actron
Old Apr 10, 2009 | 03:12 AM
Danieln's Avatar
hi guys,
I have the same issue with Evoscan 2.5
I try to connect with Evoscan 1.3 cable
I made the modifications into registry for full permissions for Evoscan program etc
I use vista 32bits.
Before I use only Ecuflash with Openport 2.0 Tactrix cable.
What I miss guys here?
Thanks
Old May 26, 2009 | 03:57 PM
Gary@MellonRacing's Avatar
same issue here man i cant get this to work man
Old Jun 18, 2009 | 09:21 PM
jluckyp's Avatar
same here, first time trying it out and i got the same error message. but i also got something about parameters cannot be null...
What exactly do we need to set?
Old Jun 21, 2009 | 02:51 PM
SLYDOGRACING's Avatar
I had a bad cable I sent it back to Hamish and Presto it has worked fine ever since
lolazour
Oct 9, 2016 03:53 PM
RA012124
Outlander Sport
19
May 6, 2014 09:23 AM
rgar
Jun 18, 2010 05:14 PM
BadazzCR
Aug 23, 2008 07:40 AM
Waz996
Dec 5, 2006 08:30 AM
