help choosing the right injectors!
so i have my install coming up next fri, will be intsalling BBK full TBE headstuds fuel pump and have my throttle bodey's gaskets replaced. currently have installed is licp FMIC cat back and arc intake box. now i know i will need injectors but which ones to get. will 750's be enough or do i need to go higher. any info would be great thanks.
i thought about it but i currently dont have the money for the set up since ide have to go with the map switch alarm box and the zeitronix set up. maybe in a couple months from now plus the nearest bump station is like 40 miles away and i dont know if i would want to be having to take the trip out there everytime i needed gas.
i too have that question. i have a tbe,larger fmic, upper and lower ic piping,gsc stage 2 cams, walbro 255 and an access port. is there a general rule on horsepower vs injectors? any help would be good. thanks
