help plz
Old Apr 10, 2009 | 01:20 AM
haseeb's Avatar
help plz
i just upgraded my map sensor from stock d jetro to aem 3.5 bar ....
now the cars runs gr8 but the commander is showing some false readings ..
eg ,if the boost is actually 2 bars the comander shows 1.2 bars peak ...
and at 1.6 bar my idc on the comander in 100% and on 2.2 bar it shows 100% also ,but my tuner says that its due to the new map sensor its reading a bit low but actually on his laptop every thing shows actuall ...
so is this normal?
Old Apr 14, 2009 | 09:13 AM
nianlala's Avatar
You will need to calibrate the new MAP sensor by setting up the appropriate offset and scale setting I believe. This is what I had to do when i changed my MAP sensor.
Old Apr 15, 2009 | 02:23 AM
haseeb's Avatar
can u guide me a little how to callibrate it ?
